Alignment price?
anyways i was quoted over the phone from Big-O tires for an alignment being $49.95 is this a good price or should i search around. I live in louisville Kentucky i figure prices will vary state to state?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow »</TD></TR><TR><TD CLASS="quote">about $20/corner where I live.</TD></TR></TABLE>
That's about right. Only a couple places around my area actually have a pit-style alignment center... My car can't make it up on all the other machines and my car is not extremely lowered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midwesta »</TD></TR><TR><TD CLASS="quote">get a lifetime, they are usually like 120-150. Then u can go whenever, especially if you have coilovers.</TD></TR></TABLE>
you cant raise your car to get an alingment and then lower it and be set....you know that right? every time you change the ride height it checnges the alignment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 »</TD></TR><TR><TD CLASS="quote">you cant raise your car to get an alingment and then lower it and be set....you know that right? every time you change the ride height it checnges the alignment</TD></TR></TABLE>
no ****, thats why i said get LIFETIME, so if you drive your car all year and raise it during the winter, you can get a new alignment, or if you are picky and change your ride height a lot.
wasnt my first post clear enough...
I meant, if you have coilovers, get lifetime, if you have a spring/strut combo, then just get a single.
While we are at it how low is too low?
And to make this post not a complete hi-jack I think just the 2 front wheels is like 45 and all 4 is 65 around here. Not 100% sure though.
darin at westend alignment in so cal does lots of lowered cars.. my car is slammed and he got it up his machine.. it was like 95 for all 4 corners with camber kits.. hes does it the oldskool way tooo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joon Joon »</TD></TR><TR><TD CLASS="quote">hes does it the oldskool way tooo
Why do you make this sound better than using a badass machine to do it like most evolved humans? Apparently it is cheaper than 'oldskool' as well!
</TD></TR></TABLE>Why do you make this sound better than using a badass machine to do it like most evolved humans? Apparently it is cheaper than 'oldskool' as well!
bmoua
Oct 23, 2006 02:56 PM
CivicSiRacer
May 12, 2003 03:18 AM
makes sense now
