b20 vtec swap??
Old Oct 27, 2005 | 01:20 PM
DA-9mordef's Avatar
Default b20 vtec swap??
do you have to change the water pump or oil pump for vtec??
Old Oct 27, 2005 | 04:04 PM
95lstegman's Avatar
Default Re: b20 vtec swap?? (DA-9mordef)
no. the oil and water pumps for '97+ non-VTEC motors including all B20B's and B20Z's are the same as the VTEC oil and water pumps. the only inferior oil and water pumps are the 1996 and older non-VTEC B-series engines. if the engine is older, however, it may be a good idea to replace at least the water pump. if it's hella old then replacing the oil pump might be a good idea, too. get pumps for the proper newer non-VTEC engine and you'll be golden.
G0dzArmy
Dec 31, 2004 03:18 PM
Tinker219
May 5, 2003 08:22 AM
JeremyL
Feb 5, 2003 08:52 PM
xaznx
Jul 25, 2002 04:30 AM
Dragger817
Jun 8, 2002 11:12 AM
