Tranny swap on a 97 prelude vtec
Old Oct 27, 2005 | 01:04 PM
damian0216's Avatar
Default Tranny swap on a 97 prelude vtec
can someone tell me some info about swaping my auto trany fora 5 speed one.. im just trying to found out wat has to be done in order for it to be done... im not worried about the tranny price just the time and labor it make take. or and other problems i would run into anyone has it done allready and would like to share please leave me some info here thanx.
Old Oct 27, 2005 | 01:32 PM
SteveoBA8's Avatar
Default Re: Tranny swap on a 97 prelude vtec (damian0216)
Search
Old Oct 27, 2005 | 02:04 PM
vietdragontekx's Avatar
i did a swap on my 97 prelude from auto to manual. my friend shop in san diego charge 1700 for labor and you buy all the parts. you need a shifter assembly, shift linkage, clutch pedal, brake pedal, manual tranny, manual ecu, and the gear selector from the auto tranny(to make the car think it still in PARK for the car to start) and manual tranny mount.
Old Oct 27, 2005 | 02:58 PM
lunarcry's Avatar
i did the swap last june on my 97 lude, as far as time it took me like 3 days doing all the work myself.
i did a write-up of this swap but i'm to lazzy to put it up, but check this one out http://www.mazmo.com/zameoj/swap.htm
ps. for the ecu u can do a conversion to manual using ur auto ecu .
Old Oct 27, 2005 | 05:17 PM
Xx D-MAN xX's Avatar
Default Re: Tranny swap on a 97 prelude vtec (lunarcry)
I don't recall reading anything about using the gear selector from the auto tranny in all the research I have done.
Are you sure this is necessary?
Old Oct 27, 2005 | 06:09 PM
Default Re: Tranny swap on a 97 prelude vtec (Xx D-MAN xX)
yes you need it, unless you want to take time to wire up the wires so it always think the car is in park. i did a obd2 to obd1 conversion with a jdm h22a too and i didn't really want to wire up car to think it in park, so i took the gear selector on the auto tranny and just plug it in to the car existing auto tranny plug on the harness. it also a cool extra feature where u can disable ur car from starting and put it on D so no one can steal ur car =D. i havn't wire up the reverse switch yet on the car. it a pain in the *** to do it. if you do the wiring on the reverse switch on the car let me know how u did it.
Old Oct 27, 2005 | 06:25 PM
K-Spec's Avatar
Default Re: Tranny swap on a 97 prelude vtec (vietdragontekx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx &raquo;</TD></TR><TR><TD CLASS="quote">yes you need it, unless you want to take time to wire up the wires so it always think the car is in park.</TD></TR></TABLE>
No, you don't need it...all you need to do is remove the TCM and do a conversion on your ECU (this can be done by relocating a chip).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx &raquo;</TD></TR><TR><TD CLASS="quote">i havn't wire up the reverse switch yet on the car. it a pain in the *** to do it. if you do the wiring on the reverse switch on the car let me know how u did it.</TD></TR></TABLE>
As for the reverse lights, you locate the A/T Gear Position Switch (it's a gray harness right above the tranny). Connect the WHT wire (from the A/T GPS) to the YEL wire (from the tranny) and the RED wire (from the A/T GPS) to the GRN wire (from the tranny).
Old Nov 4, 2005 | 05:01 PM
Default Re: Tranny swap on a 97 prelude vtec (khalal538)
aite thank, im going to try to wire up the reverse light on my car? so how does this work, everytime i put the car in reverse on my manual , manual tranny will tell that the car in reverse and the light goes on?
Old Nov 4, 2005 | 08:11 PM
K-Spec's Avatar
exactly! if you left your stock auto gauge cluster, your green "R" will light up.
Old Nov 5, 2005 | 01:26 PM
i wired it up already but everytime i put my car in reverse the light doesn't goes on. what happen? do i need to use the auto ecu or the auto gauge for this to work?
Old Nov 5, 2005 | 01:29 PM
K-Spec's Avatar
does the white back up light come on? You need an auto gauge to work, but either ECU will work.
Old Nov 5, 2005 | 01:36 PM
MadCityLude
Guest
Posts: n/a
All pedals, all hydrolic lines, clutch master, slave cylinder, shift plate, shift cables, shift cable brackets with clips,and shifter.
and here is a ebay auction with everything you need but the transmission. And I have a friend with a H22 non LSD tranny he is selling if your interested. I am in Wisconsin so pickup could be an option.
http://cgi.ebay.com/ebaymotors...%3AIT
Old Nov 5, 2005 | 06:31 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietdragontekx &raquo;</TD></TR><TR><TD CLASS="quote">i wired it up already but everytime i put my car in reverse the light doesn't goes on. what happen? do i need to use the auto ecu or the auto gauge for this to work?</TD></TR></TABLE>
Correction* Connect the WHT wire (from the A/T GPS) to the YEL wire (from the tranny) and the RED/WHT wire (from the A/T GPS) to the GRN/BLK wire (from the tranny).
WHT = YEL
RED/WHT = GRN/BLK
Old Nov 8, 2005 | 11:08 AM
im using and manual gauge cluster, will that work too?
Old Nov 8, 2005 | 11:10 AM
K-Spec's Avatar
it should...but you just won't get that green "R" light when you reverse
Old Nov 8, 2005 | 11:21 AM
so you sure it the white and red/wht wire right?
Old Nov 8, 2005 | 11:22 AM
K-Spec's Avatar
yes, try it and have your friend check to see if the back up lights come on
Old Nov 8, 2005 | 11:40 AM
bigtimlikewhoa's Avatar
Default Re: Tranny swap on a 97 prelude vtec (EuroR92Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuroR92Lude &raquo;</TD></TR><TR><TD CLASS="quote">All pedals, all hydrolic lines, clutch master, slave cylinder, shift plate, shift cables, shift cable brackets with clips,and shifter.
I bought that whole 5spd swap.. soo all i need now's the tranny and ecu yeah!
Old Nov 8, 2005 | 11:53 AM
K-Spec's Avatar
Default Re: Tranny swap on a 97 prelude vtec (bigtimlikewhoa)
if you have a 5th gen lude...some of the 4th gen parts are NOT interchangeable such as: shift cables, shifter assembly, transmission mount, half shaft, etc.
And you don't need a new ECU, you can do a conversion on your stock auto ECU (P5M), you can also use your auto gauge cluster.
Old Nov 8, 2005 | 01:53 PM
are you 100 percent sure it the white and the red/white wire?
Old Nov 8, 2005 | 06:47 PM
Are you sure 4th gen 5spd swap won't work? I've talked to people and they've said it would.. proof?
Old Nov 8, 2005 | 11:13 PM
K-Spec's Avatar
I did my own manual swap...if you don't believe me...call HONDA and ask them if the 4th gen shifter assmbly is the same as the 5th gen, they will give you different part numbers. Trust me, i'll tell you what is interchangeable...and there aren't a lot of parts that are.
Old Nov 9, 2005 | 02:18 PM
thx khalal538 got my reverse light wire up
and no 4th gen shifter assembly will not work on 5th gen, try before.
kamranm3
Mar 30, 2010 07:23 AM
fracas
Mar 11, 2010 04:20 PM
ballified
Sep 19, 2007 02:55 AM
jdm_jeners
Aug 22, 2006 06:07 PM
hooddub
Dec 14, 2004 10:03 PM
