usdm itr piston or b16 p30 which is better
ok....im going to use a b16a block and b16a head..with a thin head gasket,jdm 4-1 header,skunk 2 manifold,skunk stage 2 cams,skunk valve train ect.....what pistons would be better for a higher commpression...the usdm itr's or the b16a p30's......lemme know ...if u know
p.s,,,,,DIKEMBE MUTOMBO JUST PURCHASED A MAZDA MIATA!!!
P30 will be higher.
Check out http://www.bojangs.com for a compression ratio calculator.
It's pretty cool.....
DRAGLS
May 25, 2005 01:46 PM
