Tach jumping around
Old Oct 27, 2005 | 08:52 AM
stewmaster-k's Avatar
Default Tach jumping around
I need some help, when i slam the gas and dont shift until redline, the tach kind of freezes and it'll stop for a split second and then keep going and it does this a couple times for each gear. does anyone know what could be wrong?
Old Oct 27, 2005 | 09:04 AM
Backk InTheDA's Avatar
I hate everything
Default Re: Tach jumping around (stewmasterk)
Please try a search next time, but usually a tach that isn't responding correctly had to do w/ a distributor.
Old Oct 27, 2005 | 09:05 AM
I hate everything
https://honda-tech.com/zerothread?id=1407869
Linked for the lazy
Old Oct 27, 2005 | 09:08 AM
Default Re: Tach jumping around (BuilttB18C5)
no it wouldnt do it as bad as his, when i accelerate, the tach pretty much freezes for a second, it doesnt jump up an extra 3 grand
Old Oct 27, 2005 | 09:19 AM
I hate everything
What year is your car? Is it mostly stock?
Old Oct 27, 2005 | 09:30 AM
its a 94 rs. i have intake, header, exhaust, fpr, upped fp, stage 1 clutch, dc short shifter
Old Oct 27, 2005 | 09:58 AM
I hate everything
Only thing that i could think of would be turbo lag, and I dont even know why, because you dont have a turbo, and thats the lag for when the turbo kicks in.
Old Oct 28, 2005 | 10:01 PM
any ideas from anyone else i kind of want to get this fixed
Old Oct 28, 2005 | 11:29 PM
wob's Avatar
wob
where is ur signal wire spliced.. to the dizzy, to the shock tower harness, the cluster?? also check out ur ground.. all else fails distributor igniter may be getting ready to take a ****
Old Nov 3, 2005 | 06:39 PM
JDMKid71's Avatar
Default Re: (wob)
Mine does the same thing. however i have a 92 Civic Coupe 2 door with a Ex/si (s20) tranny. but its not only my tach that does it, its also my spedo. i cant figure out whats wrong. i took my cluster off and cleaned all the connections and put it back, swapped clusters, and still the same problem. so my guess it (the problem) is some place between the sending units and the tach. i had gotten a response a while back saying that it might be a loose ground wire... but what one? i checked all the main ones (chassis to head, tranny, starter...ect) and they were all good and making good connection. What sending unit is it that send the signal to the tach, and does it go RIGHT to the tach or tru the ECU first. i also swaped ECUs and problem is still there (i have a few extra parts laying around haha). so the only thing i can figuar out is its a ground wire someplace. or a bad sending unit. any help would be appreciated. Also. i dont think its a ECU related problem because my rev limiter is still kicking in. and if it wasn’t reading the signal right, it would rev past the rev limiter..? right? Thanks again.
ps i know this is just all over the place but bare with me. haha
Old Nov 3, 2005 | 09:43 PM
wob's Avatar
wob
the ground to the VSS.. or the VSS itself
Old Nov 4, 2005 | 06:19 AM
JDMKid71's Avatar
Default Re: (wob)
i know thats the problem with the spedo jumping. but is it the reason the Tach is also? is the VSS directly related to the Tach?
Old Nov 4, 2005 | 06:40 AM
kulrevon's Avatar
Default Re: (JDMKid71)
the vss jumping i dont think is directly related to the tach .
The tach jumping or stalling is ussually the ignitor in the dizzy. make sure the wires arent loose and add some dielectric greese.
Since you have already check the connections at the dash and the ecu?
Just make sure the harnesses on the shock towers are tight together.
Old Nov 4, 2005 | 04:57 PM
Mr. JDM-GSR's Avatar
i have the same problem but it is with my monster tach. And i know for sure that im getting a ticking inside the dizzy
Old Nov 4, 2005 | 05:46 PM
jDmDb84Dr's Avatar
check your speed censor
Old Nov 4, 2005 | 08:37 PM
JDMKid71's Avatar
Default Re: Tach jumping around (i5oLaTeD)
Sensor is spelled with a “s” big guy.
Old Nov 4, 2005 | 09:24 PM
Sack Master's Avatar
Default Re: Tach jumping around (JDMKid71)
It's probably either wiring or a bad ICM(ignitor). I would check your ICM first.
Old Nov 5, 2005 | 01:49 AM
watsvtecEK's Avatar
Default Re: Tach jumping around (Sack Master)
it is the ignitor, i have had this problem, follow these steps and it should work, and if it dose not, then you need a new ignitor, done
http://www.g2ic.com/tegtips/engine/10.html
saikouEF8
Jul 5, 2006 03:06 AM
OneThirtyEight
Jan 10, 2005 06:05 AM
ineedmoney
Jul 28, 2004 07:50 AM
USDM 4G VTEC
Jul 17, 2002 09:01 PM
