Problem: H22 345cc injectors won't fire (H23Vtec setup)
Old Oct 27, 2005 | 08:32 AM
Sunsport's Avatar
Default Problem: H22 345cc injectors won't fire (H23Vtec setup)
Well, I just finished my H23vtec setup in my 95 Prelude Si (California model if that matters)
I put the H22 injectors in (olive green tips, obd1 345cc) and the car would not start. They are definatly not fireing. I tried both the P13 and my old P14 ecu's. They would not fire. I took them out and installed my old 240cc H23 injectors and the car starts right away with either ecu. The H22 Injectors were from a working engine that dropped a valve.
I am at a loss to the problem. Anyone have any ideas? Much appreciated if you do.
Old Oct 27, 2005 | 08:41 AM
kulrevon's Avatar
Default Re: Problem: H22 345cc injectors won't fire (GT-Four)
the only thing I can think of is are you sure the 345s are from a 92-96 prelude that use the resistor box. other then that I dont know why the injectors wouldnt fire.
Old Oct 27, 2005 | 09:00 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GT-Four &raquo;</TD></TR><TR><TD CLASS="quote">
I am at a loss to the problem. Anyone have any ideas? Much appreciated if you do.</TD></TR></TABLE>
Not much you can really do except to have them cleaned and flow tested...
Old Oct 27, 2005 | 01:18 PM
Sunsport's Avatar
Update: Working now. They were gummed up. I had let them soak in fuel injector cleaner overnight. They now work perfectly. Big thanks!
Nick
KleenL
Dec 20, 2007 06:08 AM
vietxdragon
Mar 25, 2007 05:43 PM
evoalf
Mar 10, 2005 12:56 PM
DCFIVER
Sep 12, 2004 07:55 PM
