Problem installing ecu chips!
Old Oct 27, 2005 | 07:10 AM
VtecDA9's Avatar
Default Problem installing ecu chips!
So I have never had a problem installing a chip in my P28. I put one in today from a company and the car idled at 1200rpm, wouldn't go past 4000, and the check engine light stayed on. I then went to put my previous chip back in and it now would only stay on for 10 sec before it dropped to 100 rpm or so and started making a little bleeping sound when the car died. So basically I don't have a chip to run my car and was told...
"You probably installed the chip facing the wrong direction & destroyed
the chip. We do not offer returns or exchanges for improper installation."
Thanks,
Modified by VtecDA9 at 8:38 AM 10/27/2005
Old Oct 27, 2005 | 07:56 AM
drdisco69's Avatar
Default Re: Problem installing ecu chips! (VtecDA9)
Bleeping sound??? Um...
If you installed the chip backwards, it will usually nuke the chip, but not damage anything else. Double check everything on a *known good* chip and see how it does.
Old Oct 27, 2005 | 11:12 AM
VtecDA9's Avatar
Default Re: Problem installing ecu chips! (drdisco69)
Actually, my old chip does work... It works one way, which I now know is the correct way, and obviously doesn't work the other way. But it's not nuked, however it seems as if the new chip is.
Vtec140
Oct 3, 2017 02:15 AM
rexload
Engine Management and Tuning
Dec 22, 2008 07:58 PM
the jdmchop
Apr 17, 2006 08:56 AM
streetstylenperformance
Feb 11, 2004 08:45 AM
89Si
Nov 7, 2003 09:48 AM
