new tranny, with quaiffe, and gearspeed carbon covered syncros, what fluid?
Old Oct 27, 2005 | 04:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default new tranny, with quaiffe, and gearspeed carbon covered syncros, what fluid?
i have always been a proponent of honda MTF, but with this new build, which i actually did myself, and it wasnt hard, should i compliment it with redline or syncromesh or the old standby honda MTF? and if so please give oppinions on specific weights and reasoning.
Old Oct 27, 2005 | 04:29 AM
Ricey McRicerton's Avatar
Default Re: new tranny, with quaiffe, and gearspeed carbon covered syncros, what fluid? (boostedcivicsir)
I'd run the Honda MTF. I'm on a freshly rebuilt tranny myself (also self built) and I don't think there's any reason to spend the money on the FM if you're not having grinding problems. The way I had it explained to me was that the FM was just a thicker fluid, but I don't know how truthful that is.
Old Oct 27, 2005 | 05:09 AM
Mr. Badwrench
Default Re: new tranny, with quaiffe, and gearspeed carbon covered syncros, what fluid? (Ricey McRicerton)
thanks ricey. i was just feeling around, honda MTF has never let me down, but i am always looking for oppinions.
Old Oct 27, 2005 | 05:45 AM
Slow EJ8's Avatar
I have heard good things about the Redline tranny fluids. I believe there are 2 different wieghts so I the thickness of the oil is a concern for you then you can choose which fits your driving conditions/style.
Actually I have heard good things about all of them that you mentioned, if I had to choose one I would most likely try the Redline, but I would say its a toss up.
Ok I just looked it up, heres the 2 Redline MTF oils....
MT-90
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil that’s slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
MTL
This 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity) is designed for use in manual transmissions and transaxles. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting. Popular in many BMW transmissions and in most Honda and Acura transaxle applications.
So one is thicker than the other if that is a concern.
Old Oct 27, 2005 | 07:37 AM
itrhatchling's Avatar
I work at a shop that sells Royal Purplue. At first I didn't think any thing other than it was another syn oil. I was wrong. There was an independant tester that was testing products to show off his additive to improve oiling. Well the test was of a weighted bearing. put 1lb on the arm and it acts like 100lb on the breaing. On with the story the regualer napa oil took 2 plates the Red lin took three and Royal puprle took all 6 plates that he had. THe test was freaking out and he never seen an oil test so well. WITH THAT SAID i put the 10-30 in my tranny and it shifted smoother and it was quiter over all.
Royal Purple the only oil i use (after motro break in)
Old Oct 27, 2005 | 07:40 AM
whoDAT's Avatar
Default Re: (itrhatchling)
what about GM?
i know there was a big discussion about this fluid some time ago. i hear it is very good.
Old Oct 27, 2005 | 08:09 AM
Mr. Badwrench
i did see somethinglike that too, but it was for pro-long, was thinking of royal purple too.
ReaperMan
Transmission & Drivetrain
May 18, 2013 02:37 PM
Nameless RB26
Jan 23, 2003 08:24 PM
ITR1071
Oct 3, 2002 04:11 PM
lePetitePrince
Sep 29, 2002 11:43 PM
Money Hou$e
Apr 24, 2002 04:46 PM
