b20 help
Old Oct 26, 2005 | 09:29 PM
teamvirus's Avatar
My car breaks a lot!
Default b20 help
what motor is better b20b or b20z? im planning on turboing it...thanks
Old Oct 26, 2005 | 09:31 PM
Luserkid's Avatar
Default Re: b20 help (teamvirus)
Neither. The sleeves are weak. Now if you sleeve it then it doesnt matter which you get.
Get the cheaper one.
Old Oct 26, 2005 | 09:32 PM
FalkenSiR's Avatar
Default Re: b20 help (Luserkid)
b20z has more power. Like Luserkid said, the sleeves are weak unless you plan on rebuilding the motor with forged internals, resleeving it, etc...
Old Oct 26, 2005 | 09:34 PM
teamvirus's Avatar
so a n/a b20z vtec is the best setup?
Old Oct 26, 2005 | 09:35 PM
Luserkid's Avatar
B20 doesnt have VTEC.
Old Oct 26, 2005 | 09:37 PM
teamvirus's Avatar
i know..im talking about a "ls vtec"....."b20 vtec"
Old Oct 26, 2005 | 09:38 PM
Luserkid's Avatar
Well what head are you putting on.
The motor isnt going to be good unless you know waht your doing.
Old Oct 26, 2005 | 09:39 PM
teamvirus's Avatar
b20 block b16 head
Old Oct 26, 2005 | 10:07 PM
teamvirus's Avatar
Old Oct 26, 2005 | 10:19 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">b20 block b16 head </TD></TR></TABLE> Get to searching. It's been done many times
Old Oct 26, 2005 | 10:24 PM
teamvirus's Avatar
Default Re: b20 help (fast88std)
okkk...thanks 4 the info
Old Oct 26, 2005 | 10:28 PM
GapxGuy's Avatar
Sushi Buffet Champion
B20B has 8.8cr and the B20Z has 9.2 or something. B20 sleeves are weak. I have a B20vtec with 85mm bore and 11:1CR. Extremely torquey and I take it to 8,400RPM.
So do not turbo unless you're sleeving it. And if you're going N/A, do not exceed 11.5CR.
Old Oct 27, 2005 | 11:30 AM
teamvirus's Avatar
Default Re: b20 help (GapxGuy)
ok..thanks alot
Old Oct 27, 2005 | 11:51 AM
compwc18's Avatar
you could get some JE pistons and eagle rods and GE Sleeves and put a mildly built GSR head on it, and you'd be good to go.... A GSR Head is a good way to go for power.... But there are a lot of different opinions out there.... so don't just take mine do your own research....
sick90hatch
18
Nov 18, 2008 01:19 PM
hondachris1994
Mar 24, 2006 07:18 AM
crx91spoon
Dec 11, 2005 03:08 PM
horizongreyEJ1
Dec 15, 2004 05:50 PM
JdmHybrid.
52
Jun 16, 2003 11:24 AM
