compression on a gsr motor with b16 head??
Old Oct 26, 2005 | 06:10 PM
Project_EK's Avatar
Default compression on a gsr motor with b16 head??
what up,
What should the compression be on a b18c1 block with b16a2 head, and type r valvetrain? i know the comp is lower due to the b16 head. but i'm now sure where it should be??
also whats good comp, and whats bad??
thanks
Old Oct 26, 2005 | 08:06 PM
Project_EK's Avatar
Old Oct 26, 2005 | 09:14 PM
CL9WestCoastin's Avatar
Default Re: (EKhatch219)
http://www.c-speedracing.com/h...c.php
Old Oct 26, 2005 | 09:56 PM
fasthatchb18c1's Avatar
Default Re: compression on a gsr motor with b16 head?? (EKhatch219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch219 &raquo;</TD></TR><TR><TD CLASS="quote">what up,
thanks</TD></TR></TABLE>
How about you tell us.
Go through the search and find these numbers for a GSR block
1. Bore
2. Stroke
3. Deck clearance.
4. How thick the head gasket you will be using (we’ll call this HG)
Then go through the search and find what CC's are in a B16 head (how much area from deck too your valves)
With the numbers you get put them into the following to get the answer from a-d:
A= Bore x Bore x Stroke x .7854
B= Bore x Bore x Deck clearance x .7854
C= Bore x Bore x HG x .7854
D= CC's x .061
Now this is your last math problem
A+B+C+D
____________ = your Compression Ration
B+C+D
A stock GSR is 10.1 so you will see how much you gain or loose.
I'm not trying to be a dick but if you don’t try to search you will never learn
Old Oct 27, 2005 | 09:28 AM
Project_EK's Avatar
i did search..i found none that had to do with a b18 block with b16..be easy!!
Old Oct 27, 2005 | 10:36 AM
GetawayInMoscow's Avatar
I think the difference is something like .4 or .6 less, nothing major.
spidy3
Jun 4, 2008 05:44 AM
5280dc2
Apr 14, 2008 06:14 PM
92b16si
Nov 30, 2006 07:33 PM
b20_driven
Oct 14, 2006 04:38 AM
ajchen
Nov 25, 2002 07:12 AM
