ABS light
My ABS light came on today half way through the day, I'd been driving it to work and back, then it came on when I started it up to do some errands.
What's the common failure for and ABS light to come on?
It's a 2000 Accord SE.
Modified by Accord2k-Hybrid at 7:27 PM 10/26/2005
did you check your brake fluid? its probably either that, your abs sensor, or the abs pump...you should also be able to read the abs code like you do the cel, if you have the list of codes
good luck
good luck
newhondaowner29
Jan 11, 2006 08:11 PM
