Suspension & Brakes Theory, alignment, spring rates....
eg hatch with gsr suspension, which bushing kit do i buy?
Old Oct 26, 2005 | 05:09 PM
Bense's Avatar
Default eg hatch with gsr suspension, which bushing kit do i buy?
i have a 94 hatch that the former owner put gsr suspension on, as well as gsr brakes...
i know i have gsr front lower control arms because of the holes for the sway bar and i know that the rear has holes for the sway bar, because i have a gsr rear sway.
i'm not sure which upper arms are on the car,
I'm getting ready to purchase a bushing kit, but i don't now which one to buy
94 gsr or 94 civic
thanks
Old Oct 27, 2005 | 09:02 PM
b16ej1lsd's Avatar
i would say gsr
Old Oct 27, 2005 | 09:27 PM
Tad's Avatar
Tad
Default Re: (b16ej1lsd)
well i what reason would he have to change the upper arms?
and they're probably both identical anyways
check the parts number on the bushings,
they might be the same for either application..
Old Nov 1, 2005 | 09:50 PM
HiProfile's Avatar
Default Re: (Tad)
Was searching for a teg bushing kit for a reason like this, thought I'd help.
Look at the part numbers between the two cars. I know for sure that the rear LCA bushing kit is different, since the teg uses bushings that are 1/10" larger.
linky:
http://www.energysuspension.com/pages/tableco.html
Old Nov 1, 2005 | 10:53 PM
slammed_93_hatch's Avatar
Default Re: (HiProfile)
suspension is the exact some from DC(minus ITR) to eg. ONly difference might be sway bar bushings
Old Nov 3, 2005 | 06:12 AM
moto27cm's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">suspension is the exact some from DC(minus ITR) to eg. ONly difference might be sway bar bushings</TD></TR></TABLE>
Thats not true. The difference is in the rear LCA. The EH LCA's outer bushings have a 32mm diameter, while the DC's have a 35mm outer diameter.
SLowCrx
Suspension & Brakes
Apr 5, 2008 08:38 AM
20vsleeper
Suspension & Brakes
Jul 13, 2007 08:10 AM
navin
Sep 23, 2002 05:48 PM
cold_blooded
Aug 16, 2001 05:59 AM
