91 Accord Cuts off
Old Oct 26, 2005 | 10:24 AM
scottydc's Avatar
Default 91 Accord Cuts off
I started off with the typical from what I have read not starting on a hot day problem. Car has 174,000 miles no major problems. here is whats new, distributer, plugs and wires. I also replaced the relay and it died on the way to work today. a few minutes it would start a few miles die and so on till I got home. whats next, I am a little confused to what is next.
Old Oct 26, 2005 | 07:20 PM
scottydc's Avatar
Default Re: 91 Accord Cuts off (scottydc)
Starts and then when it gets warm it cuts off
Old Oct 26, 2005 | 07:46 PM
deserthonda's Avatar
did the distributor come with new ignitor and coil ???
Old Oct 27, 2005 | 05:16 AM
scottydc's Avatar
Default Re: 91 Accord Cuts off (deserthonda)
It was a complete distributor, I removed the old one and installed the new one. Where is the ignitor, is it inside the distributor, mine came with cap , rotor, etc...
Old Oct 27, 2005 | 09:22 AM
scottydc's Avatar
Can someone please tell me if the ignitor is located inside the distributor? I can't afford to keep driving my 12 mpg truck to work 120 miles a day. any help would be appreciatted.
Old Oct 27, 2005 | 10:38 AM
AK94GSR's Avatar
most likely your ignition switch
seen alot of early accords with the same problem
Old Oct 27, 2005 | 01:00 PM
scottydc's Avatar
Default Re: 91 Accord Cuts off (AK94GSR)
how easy or hard is replacing the ignition switch.
Old Oct 31, 2005 | 12:01 PM
scottydc's Avatar
I just ordered the electrical part of the ignition switch. How easy is this to install? Any help would be appreciated, 5 min, 25 min etc......
Old Nov 1, 2005 | 11:02 AM
scottydc's Avatar
Hey everyone, I just got the switch and need to install it. Is there anything tricky or is it reasonably easy. Help, Someone please let me know. I would like to install it tonight or tomorrow. I only bought the electricall part without the key. Can I get to it by just removing the covers to the steering column. Thanks in advance.
Old Nov 1, 2005 | 01:17 PM
SearchBeforeUPost!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scottydc &raquo;</TD></TR><TR><TD CLASS="quote"> Can I get to it by just removing the covers to the steering column. Thanks in advance.</TD></TR></TABLE>
Yes you can; take the upper and lower covers off and you can access the ignition cyl and switch
Old Nov 1, 2005 | 03:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scottydc &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered the electrical part of the ignition switch. How easy is this to install? Any help would be appreciated, 5 min, 25 min etc......</TD></TR></TABLE>
did u diagnose properly to make sure it is a faulty ignition switch?? or are u just going on the suggestion given to you and just hope it is the cause of ur problems......honestly i hope it is the switch so u can fix it but i will be surprised if it is ..
Old Nov 1, 2005 | 06:27 PM
scottydc's Avatar
i just cuts of completely no sputter as if fuel was cut off, I have relaced/checked distributer complete, main relay, plugs and wires which I was going to replace anyways. fuel pump comes on, you tell me.....tach just drops to bottom....
Old Nov 1, 2005 | 06:30 PM
scottydc's Avatar
also Honda wants $100 just to pull in the shop, I can buy alot of parts for that starting price and it is likely to be much more, I have gotten my money out of this car ten fold and don't mind throwing new parts at it. If I had a fair mechanic in the area that I trusted it would be a different story.
honkylion
Aug 20, 2013 01:49 AM
mastapw7
Jan 21, 2012 11:31 AM
$300lude
May 6, 2006 05:34 PM
baggelis
Feb 13, 2006 08:10 PM
