Help me identify this suspension part
Old Oct 26, 2005 | 08:29 AM
AnNiMosSiTY's Avatar
Default Help me identify this suspension part
I got a 99 GSR that was stripped that im in the process of repairing. It was lying on the ground when i got it with no wheels and it snapped a couple bolts off 3 of the suspension parts. I snapped some pics to show what im talking about. The car has some aftermarket bushings installed on it already, but the 2 fronts and the rear driverside bolt are snapped So there is no bushings on it either. What i need to know is what these bolts are called so i can go pick them up from acura today or tommorow. Also about the bushings, what kind are these and is there a way to buy the ones i am currently missing? I am worried if they come in a complete set that i dont need i only need the 2 fronts of the pic i snapped and the 1 for the rear driverside. You can see what kind they are on the rear pic theyre a red/ hot pinkish color. Ive only seen these things come in 2 colors for aftermarket, yellow and the color i got but i dont know what company makes these. If anyone could help me out with part names and numbers etc... I would gladly appreciate it.
Thanks
Old Oct 26, 2005 | 09:36 AM
projectTeG's Avatar
tell them you need the bolts for the sway bar endlinks....i believe thats what they are called. also on my bushings i have 4, i believe those are either prothane or Energy suspension
Old Oct 26, 2005 | 09:48 AM
HONDA RR's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">tell them you need the bolts for the sway bar endlinks....i believe thats what they are called. also on my bushings i have 4, i believe those are either prothane or Energy suspension</TD></TR></TABLE>
Yup its the bolts for the sway bar endlinks. You should be able to get them in auto zone or pep boys.
Old Oct 26, 2005 | 11:12 AM
ECKOTYPER's Avatar
agreed with above posts
Old Oct 26, 2005 | 11:15 AM
95lstegman's Avatar
Default Re: (ECKOTYPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR &raquo;</TD></TR><TR><TD CLASS="quote">
Yup its the bolts for the sway bar endlinks. You should be able to get them in auto zone or pep boys.</TD></TR></TABLE>
or just a junkyard if you're desperate not to spend much money. they're hella cheap new, though, even through aftermarket makers. and aftermarket ones such as Energy Suspension will be a nice upgrade as end links do a lot of work.
Old Oct 26, 2005 | 09:03 PM
Default Re: (95lstegman)
Thanks for the info guys much appreciated
Old Oct 27, 2005 | 05:33 AM
95lstegman's Avatar
Default Re: (AnNiMosSiTY)
you're most welcome
Grade50
Suspension & Brakes
Jun 17, 2013 03:27 PM
DeeJay Anton
Aug 27, 2007 10:54 PM
PIC Performance
Suspension & Brakes
Aug 18, 2005 11:38 AM
digitalh3lix
May 4, 2005 06:40 PM
