cleaning 1-piece headlamps on a DA
Old Oct 26, 2005 | 07:52 AM
ghg78's Avatar
I NIKES
Default cleaning 1-piece headlamps on a DA
was just curious on what cleaning products you guys have used,mine are kind of dingy so i'm opening them up to clean them,and dont want to use something that will fog the lenses over.
Old Oct 26, 2005 | 08:22 AM
revautousa's Avatar
PlastX from meguiars.
Old Oct 26, 2005 | 08:25 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (DA JeLLie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA JeLLie &raquo;</TD></TR><TR><TD CLASS="quote">PlastX from meguiars.</TD></TR></TABLE>
I have that, stuff doesn't work like it says it does, on my passenger side 1 piece, I have that yellow oxidation color covering it, on the PlastX bottle, it says it removes that, I even used a buffer and still nothing.
Old Oct 26, 2005 | 08:56 AM
revautousa's Avatar
Default Re: (BuilttB18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuilttB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">
I have that, stuff doesn't work like it says it does, on my passenger side 1 piece, I have that yellow oxidation color covering it, on the PlastX bottle, it says it removes that, I even used a buffer and still nothing.</TD></TR></TABLE>
If you arelready have yellowing you need to sand down the clear coat. And then use the plastx. I wouls suggest laying a few more layers of clear. Then letting it dry, and wet sand it, then use the platx on top of that. Plastx is more for protecting, and removing light oxidation. So wetsand your lights first, and remember there is probably some yellowing from the inside also.
Old Oct 26, 2005 | 09:29 AM
ghg78's Avatar
I NIKES
what grit of sandpaper,would you say to use.
Old Oct 26, 2005 | 12:35 PM
revautousa's Avatar
Default Re: (ghg78)
I started with 600 wetsand, and worked my way to to 2k. If you use too fine of a sand paper, you will be there for hours trying to get the yellowed clear off. And a tip from some people, sand long ways across the lights.
Old Oct 26, 2005 | 12:41 PM
LoseRPunKx182's Avatar
http://www.g2ic.com/tegtips/lighting/12.html
Old Oct 26, 2005 | 01:42 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.g2ic.com/tegtips/lighting/12.html</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA JeLLie &raquo;</TD></TR><TR><TD CLASS="quote">I started with 600 wetsand, and worked my way to to 2k. If you use too fine of a sand paper, you will be there for hours trying to get the yellowed clear off. And a tip from some people, sand long ways across the lights.</TD></TR></TABLE>
exactly what I did, the turnout is WELL worth the evening it took to do it...of course, then I had mine cleared to help protect them
Old Oct 26, 2005 | 01:46 PM
ghg78's Avatar
I NIKES
Cool apreciate the replies.
Old Oct 26, 2005 | 02:25 PM
nickG's Avatar
i second this...
Old Oct 26, 2005 | 07:34 PM
importdude2000's Avatar
Default Re: (nickG)
need i say more?look at teg tips in bg
also the finsih results was HAND BUFFED ONLY~~~~
never got to take pictures of it being buffed with a machine
which is 50% shinyer
Old Oct 27, 2005 | 07:25 AM
Default Re: (importdude2000)
those turned out great for hand buffing, that's what mine looked like before I had them cleared and buffed...it's worth the extra 60bones to have it done and protects them nicely
damn nice job
Old Oct 27, 2005 | 07:53 AM
revautousa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I think maybe that green box up there helped you the most on this project.
Old Oct 27, 2005 | 07:58 AM
ghg78's Avatar
I NIKES
those turned out awesome
Old Oct 27, 2005 | 08:10 AM
MenaceL.A.671's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">need i say more?look at teg tips in bg
sweeet... well we use mother's polish!!!!! even without sanding it down!!!!!
Old Oct 27, 2005 | 08:29 AM
MAV3RiCK478's Avatar
Default Re: cleaning 1-piece headlamps on a DA (ghg78)
turtle wax polishing compound does the trick until i lay some new clear on them. i did the teg tips but didnt reclear my passengerside so it yellows after awhile. just rub some polishing compound and the yellow comes off. the car is getting repainted soon so i will have my lights recleared with a good UV protectant clear and hopefully wont be polishing them anymore.
Old Oct 27, 2005 | 08:41 AM
SwedBoy2999's Avatar
I used some 3M perfect it 3.
Turned out good.
Old Oct 27, 2005 | 08:47 AM
Default Re: cleaning 1-piece headlamps on a DA (SwedBoy2999)
what is this 3m perfect stuff you speak of? I used the sand paper 400/600/800/1000/1500/2000 and then turtle wax red then green....then clear....
but what is this stuff?
Old Oct 27, 2005 | 02:39 PM
i should take pictures of the light right now
i used a buffer on it last week..cuz i didnt clear it so it turned kinda yellow since i buffed it the first time which was 6months ago
wow its shinny
Old Oct 27, 2005 | 03:18 PM
ghg78's Avatar
I NIKES
no idea i'd get this many responses,thanks alot though
Old Oct 27, 2005 | 03:35 PM
kNOwLedGeDA9
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwedBoy2999 &raquo;</TD></TR><TR><TD CLASS="quote">I used some 3M perfect it 3.
Turned out good. </TD></TR></TABLE>
Please tell us what 3M product you used!!!!!!!
Old Oct 27, 2005 | 04:47 PM
Spectrum24x's Avatar
You dont need 2 sets of one pieces Ill take one off your hands
Old Oct 27, 2005 | 06:15 PM
Default Re: (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">
You dont need 2 sets of one pieces Ill take one off your hands </TD></TR></TABLE>
that has at lease 6-8 months ago
and that was for my brothers da and mine
but ull love this picture even more
this was only ONE TRIP TO THE jdm house
i made at lease 3 trips
Old Oct 27, 2005 | 06:23 PM
BACKintheDA's Avatar
in for the 3M
Old Oct 27, 2005 | 06:36 PM
Default Re: cleaning 1-piece headlamps on a DA (kNOwLedGeDA9)
http://products3.3m.com/catalo...d_3_0
^I'm pretty sure that's the stuff. Keep in mind my headlights were not in too bad shape when i got them. We had it lying around the garage so i gave it a whirl and it looked pretty good. I buffed it out more than once. This was all done by hand though. If i had a porter cable buffer oh man those lights would look new.
I'll check the bottle when i get home. Since my aunt is the head of government relations for 3M we try and support the company.
