94 Accord Tech Question??
It will not start.
The starter works fine and keeps trying, but will not completely turn over.
Seems like a fuel problem or possible main relay??
Any suggestions?????
Phill
Phill
Also it is only in the morning when it is cold, once it warms up and the sun comes up it does finally start.
I will check for spark and the fuel filter when I get off work.
Thank you.
Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Accord2c »</TD></TR><TR><TD CLASS="quote">It will not start.
Phill
PHIL........... u need to diagnose if it is not starting because of , lack of spark or lack of fuel. Get a can of carb cleaner, remove the tube that goes to the throttle body, spray some in there if car starts it is lack of fuel, i would then chk the main relay.............
Phill
darithS
23
Jul 11, 2008 09:00 PM
AznPrideYo
Feb 21, 2004 07:16 AM
