pulling a b-series from a EG hatch
Old Oct 25, 2005 | 10:01 PM
eviltwin66six's Avatar
Default pulling a b-series from a EG hatch
yo i have a b16 in my EG...im going to pull it out over the winter..does anyone have a guide or something to help me do everything right?im pretty sure i can pull it out but i am worried bout wires/electrical system..i wana pull it n put the motor back in..becuz the best way to learn is to do it yourself..so if anyone has anything that wud help it would b greatly appreciated...Twin Tech..
Old Oct 25, 2005 | 10:40 PM
RedHB..D15B's Avatar
Default Re: pulling a b-series from a EG hatch (eviltwin66six)
everything is pretty obvious, once you start taking things apart, you'll remember where all the plugs/parts go...if you dont, pm me and ill help you out.
Old Oct 25, 2005 | 10:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: pulling a b-series from a EG hatch (RedHB..D15B)
Just unplug the harness' at the shock towers. Undo everything else, and pull her out. Hardest part will be the bitch pin.
Old Oct 25, 2005 | 10:57 PM
Default Re: pulling a b-series from a EG hatch (JDM_Ej)
bitch pin?
Old Oct 25, 2005 | 11:14 PM
wob's Avatar
wob
obd1 swaps are cake.. undo the shock harnesses , axles . fuel lines ,coolant lines ,slave, mounts and pull that ******.. the bitch pin is on the shift linkage.. usually its taken out with the ac bolt... but i usually leave it on...
Old Oct 25, 2005 | 11:35 PM
JDMlyfestyle's Avatar
disconnect the shift linkage from the shifter and pull it out with the engine
jdmsir4dr
Apr 22, 2013 04:46 AM
95f22a1
May 17, 2008 10:59 PM
94eg5squadMD
Mid-Atlantic (Sales)
Oct 19, 2007 03:29 AM
jadugartir
Nov 26, 2005 02:58 PM
untitledsn41
10
Jul 11, 2004 08:34 PM
