JDM 1 Peice Headlight Installs on 90-93 Integra
I know to search, and I have.
Crappy thing is that I can't find anything so if anyone could help me out and let me know a little about what I'd have to do to install these headlights I would greatly appreciate it, the stock OEM replacements I have don't light for anything and makes night driving a pain so I finally decided I would go with the 1 Pc.
Any HELP is appreciated.
use the bulbs that came w/ you lights...cut your harness and match your wires to the wires on the bulbs
http://www.g2ic.com
go to the teg tips, lighting, theres a detailed write up...
http://www.g2ic.com
I am a member there, didn't even think of them, I always use H-T before anything else.
What number code are the JDM bulbs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin »</TD></TR><TR><TD CLASS="quote">Damn, So I'd have to order some if I ever blew any...</TD></TR></TABLE>
or convert to h4....dont ask..look on g2ic
From: Good luck to this industry, you're gonna need it.
I JUST did my 1pc's last weekend....
with the bumper, take the two screws off at the wheel well
center bolt for bumper 10mm
two bolts 12mm on either side of bumper behind turn signal
release fender lining
on marker/turns take them out and take out the two screws that holds the bracket it
drop bumper
headlights
unbolt top sections
unbolt bottom sections
remove headlights
you will have to find the headlight wiring on http://www.G2ic.com...it's not that I don't rememeber this, you need to do some work for yourself
drop bumper
headlights
unbolt top sections
remove headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 »</TD></TR><TR><TD CLASS="quote">All of the wire colors from the one pieces correspond with the stock headlight wiring. All you gave to do is cut the wires and match colors.</TD></TR></TABLE>
SHHHH....damnit don't tell all the secrets...
exactly right, except on the FAR outside corners, they are two slots horizontal and the plug on your car is one slot horiz and one vertical....you'll have to change that one...otherwise, you're good to go
see, no more secrets
...see, no more secrets
deanh8
Jul 22, 2006 11:07 AM
