GSR-Hatchback driver side door problem
Old Oct 25, 2005 | 04:14 PM
tegpilot007's Avatar
Default GSR-Hatchback driver side door problem
For some reason (possibly due to someone sticking a wedge in the door when the door was shut and locked, i.e. attempted theft) the driver side door has been sprung. When I shut it, the door edge near the handle sticks out of the frame about a 1/4 inch, which triggers the door locking mechanism to fail, which causes the alarm to not arm and will cause the door open light to well, light. Does anyone know of a solution to this problem. Can I reset the door in the frame or do I need to replace it. Any advice would be helpful.
RWFF
Old Oct 25, 2005 | 05:16 PM
vinai's Avatar
Default Re: GSR-Hatchback driver side door problem (tegpilot007)
You can adjust the door so it is further in If that happens to be the problem. Is the entire door sticking out further or what. There is four bolts that hold the door on to the hinge that is how you just the door in or out. Do it on a flat surface and use a jack. If you have any ?? just e-mail me I just adjusted my door to far up and to far out!!
Mychal71
Mar 20, 2022 01:32 PM
hondaon18's
Jan 2, 2013 07:02 PM
suhteevin
Jan 6, 2009 09:04 PM
PatrickGSR94
Feb 10, 2004 03:38 AM
