S CA b18a built block
Old Oct 25, 2005 | 02:07 PM
str8sleepr's Avatar
Default S CA b18a built block 650 takes all
I have a B18A block bored 40 over with type r pistons. The block has been decked and hot tanked. The rods have been renotched and have GSR rod bearings. It also has brand new LS main bearings, all new gaskets,brand new Type R oil pump, brand new LS timing belt.BLOCK IS NOT put together and is MISSING MAIN CAPS.(SO YOU WOULD HAVE TO GET SOME MACHINED TO FIT) You would also need a water pump. I spent over $700 on this block and have no use for it. Taking offers!! Willing to part out if no one is intrested in buying all. Work was done by RS.
B18A BLOCK bored 40 over, decked,hot tanked, missing main caps ( would need a new set of main caps and get them align bored. I think its cost like $70-100) - $110
RS MACHINE Over sized Type r pistons - $150
Ls Rods renotched with gsr bearings-$ 140
Gaskets all new top and bottom!- $130
New Ls timing belt- $30
New Type r oil pump-$100
RC Injectors 270cc used (peak and hold)- $120
Gude (Bullfrog) ECU obd-0 - $100
Modified by str8sleepr at 1:07 AM 1/30/2006
Modified by str8sleepr at 1:08 AM 1/30/2006
Modified by str8sleepr at 1:58 PM 4/19/2006
Old Oct 26, 2005 | 01:38 PM
str8sleepr's Avatar
Default Re: S CA b18a built block (str8sleepr)
ttt
Old Oct 26, 2005 | 02:59 PM
str8sleepr's Avatar
bump
Old Oct 26, 2005 | 03:43 PM
cjay's Avatar
how much do want for the injectors?
Old Oct 26, 2005 | 06:27 PM
str8sleepr's Avatar
Default Re: S CA b18a built block (cjay)
cjay- 160 for injectors.
Old Oct 27, 2005 | 11:29 AM
str8sleepr's Avatar
up
Old Oct 27, 2005 | 01:59 PM
str8sleepr's Avatar
ttt
Old Oct 27, 2005 | 06:53 PM
str8sleepr's Avatar
night bump
Old Oct 28, 2005 | 08:25 AM
str8sleepr's Avatar
morning bump
Old Oct 30, 2005 | 01:54 AM
str8sleepr's Avatar
TTT
Old Oct 30, 2005 | 11:23 PM
str8sleepr's Avatar
bump
Old Nov 1, 2005 | 01:36 PM
str8sleepr's Avatar
up
Old Nov 1, 2005 | 08:46 PM
str8sleepr's Avatar
to the top
Old Nov 6, 2005 | 12:17 AM
str8sleepr's Avatar
early mornin bump
Old Nov 8, 2005 | 11:19 AM
str8sleepr's Avatar
ttt
Old Nov 9, 2005 | 05:38 PM
str8sleepr's Avatar
noone ?
Old Nov 11, 2005 | 04:54 PM
str8sleepr's Avatar
bump
Old Nov 12, 2005 | 10:52 PM
str8sleepr's Avatar
bump
Old Nov 15, 2005 | 10:17 AM
str8sleepr's Avatar
TTT
Old Nov 16, 2005 | 04:50 PM
str8sleepr's Avatar
Old Nov 17, 2005 | 11:45 AM
str8sleepr's Avatar
up
Old Nov 17, 2005 | 05:40 PM
str8sleepr's Avatar
Old Nov 19, 2005 | 02:33 PM
str8sleepr's Avatar
anyone?
Old Nov 22, 2005 | 12:56 PM
str8sleepr's Avatar
bump
Old Nov 22, 2005 | 02:26 PM
str8sleepr's Avatar
