Honda S2000 Honda S2000
My hood came in.......=)
Old Oct 25, 2005 | 01:23 PM
revvin9k's Avatar
Default My hood came in.......=)
Well, through all the crap that i've been through with my car and my top, there is finally some light at the end of the tunnel...thanks to Bulletproof for the prompt service.Hood will go on Monday when I take it to the shop to repair the damge to my car.
Old Oct 25, 2005 | 01:33 PM
WowOzYouRock's Avatar
Default Re: My hood came in.......=) (S2K NUB)
dont drill that hood!!!!! thats the worst thing you could do ... plus that hood pins sucks
Old Oct 25, 2005 | 01:35 PM
Default Re: My hood came in.......=) (Y2K_S2K)
i see you have J's exhaust comin, go order urself a ricks2k exhaust cap
Old Oct 25, 2005 | 01:40 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">i see you have J's exhaust comin, go order urself a ricks2k exhaust cap
DROOL.....which is that the 60rs???I already have the cover from Ricks. How loud is that and should I not even bother with hood pins?
Old Oct 25, 2005 | 01:47 PM
YUP dats the 60rs ... its not even loud with the cat ... then i put custom test pipe, and the sound is just sex ... with the J's intake, you might have to cut the hood from the inside depends if you have any room for the snorkle ...
p.s. dont bother with the hood pins
Old Oct 25, 2005 | 01:53 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">YUP dats the 60rs ... its not even loud with the cat ... then i put custom test pipe, and the sound is just sex ... with the J's intake, you might have to cut the hood from the inside depends if you have any room for the snorkle ...
p.s. dont bother with the hood pins</TD></TR></TABLE>
You're gonna have to give me your number so you can help me cut the hood if I need to.
But Ben at Bulletproof said that the Top Secret hood provides enough clearance for the J's intake. The intake won't be here for another month so we'll see what happens. What intake are you running?
Old Oct 25, 2005 | 01:56 PM
i had the ARC then i sold that .. running stock right now ... custom stock box that is
HXMan's Avatar
Don't do the hood pins man.
Old Oct 25, 2005 | 01:59 PM
revvin9k's Avatar
Did you sell it to Andrew(Cone)?
Old Oct 25, 2005 | 02:00 PM
Default Re: My hood came in.......=) (HXMan)
here ... you should get those tein hood damper (so i can call you NO ORIGINALITY)
Old Oct 25, 2005 | 02:01 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Don't do the hood pins man. </TD></TR></TABLE>
Can someone please tell me why? I thought that hood pins were "somewhat needed" with CF hoods, even though I never had em on my Sol. Can I drill for the washer nozzles at least?
Old Oct 25, 2005 | 02:03 PM
i think its already drilled for the washers ...
Old Oct 25, 2005 | 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K NUB &raquo;</TD></TR><TR><TD CLASS="quote">Did you sell it to Andrew(Cone)?</TD></TR></TABLE>
yeah that bastard wouldnt leave me alone ... so i sold it to him
Old Oct 25, 2005 | 02:05 PM
Nishant's Avatar
It should be drilled for washers like Oz said.
Hood pins are not necessary because your hood is heavier than the oem one. Now if you had a dry carbon fiber hood, which is super light, you would need hood pins. The company you bought your hood from will always tell you to get hood pins as its a safety requirement for them to offer it to you
Old Oct 25, 2005 | 02:11 PM
Default Re: My hood came in.......=) (Nishant)
is it authentic Top Secret hood? it should be dry carbon if its authentic and i say you dont need hood pins ... just look @ mugen hood in urmil's car, he didnt need hood pins
Old Oct 25, 2005 | 02:17 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">is it authentic Top Secret hood? it should be dry carbon if its authentic and i say you dont need hood pins ... just look @ mugen hood in urmil's car, he didnt need hood pins </TD></TR></TABLE>
Yeah it's the real Top Secret piece. I appreciate all the feedback, glad I did'nt jump the gun and do something stupid. After all I am the S2K NUB.....
Nishant's Avatar
i never got a chance to look at urmil's car closely
Old Oct 25, 2005 | 02:28 PM
revvin9k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">here ... you should get those tein hood damper (so i can call you NO ORIGINALITY)
Just ordered em. I am no longer original.........
Old Oct 25, 2005 | 02:34 PM
order it from evasivemotorsports ... while ure @ it, get the J's engine torque damper, J's oil cap, J's valve cover, and J's Radiator cap ..
then ...
go back to bulletproof or AJR and get the J's oil catch can / rad fluid over flow tank
Old Oct 26, 2005 | 08:06 AM
Luder94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i never got a chance to look at urmil's car closely </TD></TR></TABLE>
Yeah...you were too busy trying to get some pancakes with the ITR guys. Actually, by then, I had already been at lunch for close to 1.5 hours, so I had to run anyway.
Yup...no pins needed for a reinforced dry CF hood. I'm not sure about the Top Secret, but if the underside is reinforced, you shouldn't need the pins. If it's just a hood lid, you may need to do the pins. However, I suggest not doing so. With a vented hood, you have a much less chance of the hood peeling back at high speed. The air pressure on either side of a vented hood at speed shouldn't be great enough to "blow open" the hood. On a non-vented hood with weak latching, this could be a major issue....especially with a hood length as long as the S2K.
Old Oct 26, 2005 | 12:59 PM
eMpAtHy's Avatar
Default Re: My hood came in.......=) (Luder94)
i've heard stories of hoods flying back at windshields..
Old Oct 26, 2005 | 01:04 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: My hood came in.......=) (eMpAtHy)
Yea, from people forgetting to push their hood down all the way, buying cheap 1 ply hoods, shitty install... There will always be stories.
Old Oct 26, 2005 | 03:10 PM
papa5murf's Avatar
Default Re: My hood came in.......=) (Slideways2000)
only use hood pins if they have a lock on it...
Old Oct 30, 2005 | 04:12 AM
Mobil_1's Avatar
engine bay is hotnes
Old Oct 30, 2005 | 08:02 AM
GEN2TEG's Avatar
RE:Hoodpins
When you drill into carbon fiber like that, eventually it will start to crack around the area in which you drilled for the hood pins.
Don't do it. It looks cleaner without them anyway.
