how do people get their Endyn/z10 breather kits line steel braided?
Old Oct 25, 2005 | 12:59 PM
RuthlessEF-9's Avatar
Default how do people get their Endyn/z10 breather kits line steel braided?
i know how to do the one on the tank itself...what im stumped on is the nipples that go to the block. Since both of them are bead rolled. where/how can I get those fitting to accept -an fittings? are there special plugs out there the same size as the plugs where I can put -an fittings
Old Oct 25, 2005 | 03:53 PM
Pro-Am 1934's Avatar
Default Re: how do people get their Endyn/z10 breather kits line steel braided? (RuthlessEF-9)
Measure the diameter of the nipples (should be 1/2"). The take a tube cutter and cut the flare off of it. The you can get the fittings from Earls that have the tube to AN pieces. Essentially it is a crush washer that forms around that tube once you tighten it.
Similar to this right here. They do make a 1/2" one, I have a couple at home.
http://www.holley.com/products...06ERL
Jason
Old Oct 25, 2005 | 04:19 PM
Jared's Avatar
I cut the rolled part off the block fittings and welded on steel -8 male fittings. same with the catch can, but aluminum.
Old Oct 25, 2005 | 05:04 PM
Tuned1's Avatar
Default Re: (Jared)
What he said^^^^ great idea. Or a -10 hose fits nice use a hose clamp to secure it.
Old Oct 25, 2005 | 07:56 PM
thanks for the help guys
FlewByU352
Jan 5, 2012 06:13 AM
maxogsr
18
Dec 27, 2008 03:41 PM
flat-blk-HB
Apr 28, 2003 04:50 PM
