Throttle Body Torque Specs
Old Oct 25, 2005 | 10:29 AM
turboxsi's Avatar
Default Throttle Body Torque Specs
How many lbs of torque do you guy tighten down your throttle body with. The four bolts on the studs that is. This is for a itr throttle body btw. TIA
Old Oct 25, 2005 | 10:35 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Throttle Body Torque Specs (turboxsi)
This isn't for an Integra Type R, but it may be of help, because I have a feeling it's the same.
From the Helms for a 94-01 Integra RS/LS/GS/GSR:
The throttle body has two bolts, and two nuts that screw onto studs. Both the nuts and the bolts are 8 x 1.25mm and should be torqued to 16 ft-lbs.
Old Oct 25, 2005 | 11:12 AM
turboxsi's Avatar
Default Re: Throttle Body Torque Specs (shamoo)
Thank you shamoo for the quick response!!! I can finish up now.
turboxsi
Feb 19, 2021 09:23 PM
dacratic
Honda Civic (2001 - 2005)
Mar 25, 2016 12:46 PM
atariz81988
Aug 15, 2007 06:19 PM
atariz81988
Aug 15, 2007 03:49 PM
