05 RSX TYPE S PROBLEM
Old Oct 25, 2005 | 07:36 AM
CpRiCe87's Avatar
Default 05 RSX TYPE S PROBLEM
I iust recently bought an 05 rsx type s and after about 2500 miles i started hearing a rattling noise when i would rev my car out to about 3100 rpms...i just took it to the dealership today and had a chat with a tech there who also owns a 05 type s and was told that the rattling noise im hearing is a heat shield that covers the cv boot...a quick fix is to take the heat shield off but then you risk melting you cv boot...so im guessing the best way to fix this problem is just to put a hks hi-power on it so i dont hear it anymore!!! ANY SUGGESTIONS??
Thanks in advance!
Curt
Old Oct 25, 2005 | 10:31 AM
Flexin_B18's Avatar
Default Re: 05 RSX TYPE S PROBLEM (CpRiCe87)
shure
Old Oct 25, 2005 | 01:08 PM
255.255.255.255.'s Avatar
Never heard of this problem. I would rather have the rattle and prevent a melted cv boot which is a pain to replace. If you want to get a new exhaust system then by all means boy, go at it. I would suggest that the heat shield remain.
Old Oct 25, 2005 | 02:06 PM
f1nal zeros's Avatar
Just bend the plate back a bit.
This is a common problem with the 02-04 rsx's, it happens just get some pliers and bend it backwards a bit so it will not hit.
Old Oct 26, 2005 | 06:37 AM
keenspeed94's Avatar
Default Re: (f1nal zeros)
i work for a dealer and i have had 2 cars with that rattle and if u bend that shield above the pass. side axle just bend it upwards.
Old Oct 26, 2005 | 12:06 PM
teknoracing's Avatar
Default Re: (keenspeed94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keenspeed94 &raquo;</TD></TR><TR><TD CLASS="quote">i work for a dealer and i have had 2 cars with that rattle and if u bend that shield above the pass. side axle just bend it upwards.</TD></TR></TABLE>
I can verify this.
Melted CV boots =
Old Oct 26, 2005 | 02:04 PM
HONDA RR's Avatar
I think your idea is the best and the most safest.
Old Oct 26, 2005 | 02:51 PM
thrty8street's Avatar
Default Re: 05 RSX TYPE S PROBLEM (HONDA RR)
shouldnt it be under warranty? so why should you have to worry about it
Old Oct 26, 2005 | 10:33 PM
CpRiCe87's Avatar
It is under warranty but, they said its something they just cant fix...they said you just kinda have to deal with it
carvalho1910
May 20, 2011 09:42 AM
portaman03
Feb 15, 2008 08:33 AM
Window_Shopper
14
Dec 7, 2005 04:26 PM
Civic92Turbo
52
Sep 25, 2005 10:49 AM
