looking for 92-95 caliper bolt??
im needing a caliper bolt for a 1994 civix dx coupe ,left front (lft&rht are the same i believe)calper bolt. long skinny one with only like halfway threaded..
for a non abs vehicle(not shure if that is a factor??
had one break. on a brake job-now using a fasten all bolt and the brakes squeel horibly, local h-dealer say cannot locate a single bolt without buying the whole caliper.. um no...
was advised to shop salvage yards... so far no jdm parts to locate at them....
any help appreciated....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primed 1 »</TD></TR><TR><TD CLASS="quote">as above , local h-dealer. etc..... cannot get........ thanks for the quick reply.</TD></TR></TABLE>
They are liars they can get any part you can point to on thier diagram. Go to the site and find it on the diagram for Component : FRONT BRAKE (DX) Then just find the bolt you need in the diagram and order it. If you can order it on that site then your local dealership can order it.
http://www.hondaautomotiveparts.com/
slacks
10
Mar 3, 2008 08:51 PM
It may cost a fwe bucks but you will get a shinny new bolt that you know is correct
