S2000 cockpit into civic 5th gen
Old Oct 25, 2005 | 05:24 AM
Tahar's Avatar
Default S2000 cockpit into civic 5th gen
can somebody tell me if a S2000 cockpit can be build into a civic 92-95....
Old Oct 25, 2005 | 05:25 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: S2000 cockpit into civic 5th gen (Tahar)
Get me a dash and I will make it work. As for the cluster, that's still in testing phases but the wiring has been completed. I believe a kit will be available sometime soon.
Old Oct 25, 2005 | 05:35 AM
Tahar's Avatar
Default Re: S2000 cockpit into civic 5th gen (litterbox)
thanx .....its about the cluster
Old Oct 25, 2005 | 06:52 AM
JDMlyfestyle's Avatar
I havent heard anything about a kit but im still tryin to figure out the microcontrollers to Intensify the signal and still be accurate.
Old Oct 25, 2005 | 06:58 AM
Anthony's Avatar
Mr. Fuch-yu
Have to give a to litterbox. If you are doubting him check this out:
https://honda-tech.com/zerothread?id=1211255
And he helped out with advice and whatnot on this swap:
https://honda-tech.com/zerothread?id=1412565
This should get rid of any doubt.
-Red
Old Oct 25, 2005 | 07:15 AM
well the S2000 uses a digital Signal for the Temperature gauge and Speedo. but everything else will work.
Im working on the coding in the Microcontroller to get is right but it isnt as easy as it sounds
Old Oct 25, 2005 | 07:47 AM
HOUCK's Avatar
Default Re: S2000 cockpit into civic 5th gen (nitrared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrared &raquo;</TD></TR><TR><TD CLASS="quote">Have to give a to litterbox. If you are doubting him check this out:
-Red</TD></TR></TABLE>
Yeah Litterbox Roxzorz MySonxorz.... get him to do it for u.. i've seen his ****
Old Oct 25, 2005 | 07:49 AM
litterbox's Avatar
Default Re: S2000 cockpit into civic 5th gen (HOUCK)
Get offmy nuts0rz
Old Oct 25, 2005 | 09:17 AM
shifty35's Avatar
A guy in the UK on PGMFI.org has successfully transplanted the cluster into a CRX last I saw. The frequency coming out of the VSS has to be modulated for the cluster, and you can remove the cluster's rom and edit it to change the mileage. It's a pretty electrically intense mod...
Old Oct 25, 2005 | 09:20 AM
ya that would be mark.. he shows it all on a bench test. Still no videos of it in action and hasnt done the temperature yet either.
Old Oct 25, 2005 | 09:24 AM
mwieczorek43's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">well the S2000 uses a digital Signal for the Temperature gauge and Speedo. but everything else will work.
Im working on the coding in the Microcontroller to get is right but it isnt as easy as it sounds</TD></TR></TABLE>
JDM i have no idea what you just said.... but you're still my hero.
Old Oct 25, 2005 | 09:31 AM
92ehatch's Avatar
Default Re: (mwieczorek43)
its not as easy as it sounds JDM??
that doesnt sound easy at all lol
good luck with it
Old Oct 25, 2005 | 05:59 PM
shifty35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">ya that would be mark.. he shows it all on a bench test. Still no videos of it in action and hasnt done the temperature yet either.</TD></TR></TABLE>
I would assume the cluster either takes a 0-5v or 4-10 mA standard analog signal... shouldn't be hard to convert to with a MC that handles A/D...
Old Oct 25, 2005 | 06:05 PM
xdrian's Avatar
Default Re: (shifty35)
Pacman had it installed in his crx, but only the tach worked
evo951
35
Dec 13, 2014 10:52 AM
Tahar
Honda S2000
10
Oct 29, 2005 10:01 PM
