Two questions: one about koni reds and the other about a beaks kit
This thread is too all the owners of Koni Reds and a beaks kits...
in the current state, I am returning my car back to bone stock....and the first order of business is the rear sway bar....
I had OEM itr rear sway bar and was using the beaks kit...so now that I am going to back to the stock 13mm, how hard is it too install the OEM rear sway bar again?
mind you in the beaks kit it said something along the lines of removing these two mounting plates in order for clearance of the beaks kit....so do you think I could live without the bracket and juss bolt it back in as if it were stock again?
Second question is Koni Red owners, As some of you understand they are height adjustable...
is the height settings (FOR THE FRONT SHOCKS), based on this:
Flip the spring cup = lower ride height
Do not flip the spring cup = OEM height
is this right ? or am i wrong?
thanks for all your help
