Where can i get aftermarket lower control arms for my EP3?
Old Oct 24, 2005 | 05:32 PM
EP3RACER12's Avatar
Default Where can i get aftermarket lower control arms for my EP3?
i was looking at my driver side control arm and noticed it was tweaked a little bit, most likely from last winter when i had slid into the curb. i went to honda and an oem lca is about 200 bucks. does anyone know where i can get an aftermarket lca, and if they make aftermarket lca's? i thought skunk2 would have them but i was not able to find it.
Old Oct 24, 2005 | 06:21 PM
97 TYPE-R 312's Avatar
Default Re: Where can i get aftermarket lower control arms for my EP3? (EP3RACER12)
SPC!
-Victor
Old Oct 25, 2005 | 07:50 PM
EP3RACER12's Avatar
Default Re: Where can i get aftermarket lower control arms for my EP3? (97 TYPE-R 312)
i looked a SPC but i could only find rear lower control arms... im looking for front lca's. does skunk2 have any available?
Old Oct 25, 2005 | 08:00 PM
Kal's Avatar
Kal
mugen has some for the CTR $575 for two front ones.
Old Oct 25, 2005 | 09:05 PM
Default Re: Where can i get aftermarket lower control arms for my EP3? (Kal)
Go find a set of DC5R LCA's used and the DC5R sway bar to go with and you'll still come out cheaper than the Mugen bushing equipt JDM LCA's. I'm for the Mugen setup, but if you're not going to track the EP, it's really not needed.
-Victor
Old Oct 26, 2005 | 04:42 PM
WilkesEP3's Avatar
I'd deff go with the Mugen. Expensive, yes, but lightweight and will fit your USDM EP3 like a glove with those bushing inserts.
Old Oct 26, 2005 | 05:34 PM
EP3RACER12's Avatar
alright ill check that out, thanks
Old Oct 26, 2005 | 05:35 PM
EP3RACER12's Avatar
so basically the ep3 and the rsx are based on the same parts? everything suspensionwise is the same? i know they have 5 lug instead of 4 but other than that is everything the same?
Old Oct 28, 2005 | 11:37 PM
BarracksSi's Avatar
Many things are the same, or will at least bolt up somehow. The Mugen/OEM ITR front LCA's will bolt up and add some negative camber, if I recall correctly. The only difference between the Mugen and stock Honda versions are the bushings; otherwise they're the same lightweight aluminum arms that also require an ITR front sway (mounting points are different than the EP3/RSX's).
ComeOnKip
Suspension & Brakes
13
Oct 29, 2008 12:07 PM
Mugen_DC2R
Sep 28, 2006 02:25 PM
importboi22
Suspension & Brakes
11
Feb 28, 2005 12:33 AM
Ausmith
Mar 2, 2004 07:58 AM
Rain_man
May 1, 2003 09:12 AM
