Car will not stay warm
Old Oct 24, 2005 | 05:28 PM
92eg6's Avatar
Default Car will not stay warm
i have a 97 civic w/a 2000 b16, first of all my car when i warm it up it takes for ever to move from C, so i start drivin, and if i turn on the heat my car temp goes rite back down from half way between C and H to C, if i turn it off it goes rite back up. can this all be caused by the thermostat?
Old Oct 24, 2005 | 05:34 PM
old man neri's Avatar
Default Re: Car will not stay warm (92eg6)
A faulty thermostat could cause that.
Tell me, if your car is ideling/not moving/not in the wind, does it warm up? when you go on the highway, does it go right back to cold?
Old Oct 24, 2005 | 06:38 PM
EG2Driver's Avatar
Default Re: Car will not stay warm (old man neri)
i have the same problem....when i drive, it goes down halfway. Same engine. I just got home, and the top hose was hot and the bottom hot, but not as hot as the top one. The heat coming out of the vents stayed consistantly hot. I need help with this...cold engine means sludge buildup and canadian winters are cold and it takes forever for my car to warm up...even driving on hte highway it takes a while. Thanks for the help
Old Oct 24, 2005 | 07:18 PM
Default Re: Car will not stay warm (deadend9009)
If it eventually heats up when standing still but then cools off when driving/in motion it usually means your thermostat is stuck open. The Heater is just another way to cool off the engine, it is really just a secondary radiator (that's why if your engine starts to over heat you crank the heat on)
I think Helms has a good diagonsis matrix in it.
Old Oct 24, 2005 | 07:26 PM
littleredcivic's Avatar
if you have a hot hose on top, but a cold hose on the bottom, that can be a water pump needing attention if you have already tested the thermostat. to test a thermostat, pull it out and boil some water with the thermostat inside it. at the temperature it is designed to open at, you will see the center portion open. place a high temperature thermometer in the water to see when it opens. you can also let the water cool and see when it closes. most honda thermostats are going to open around 170-180 deg F.
Old Oct 24, 2005 | 07:35 PM
Default Re: Car will not stay warm (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">if you have a hot hose on top, but a cold hose on the bottom, that can be a water pump needing attention if you have already tested the thermostat. to test a thermostat, pull it out and boil some water with the thermostat inside it. at the temperature it is designed to open at, you will see the center portion open. place a high temperature thermometer in the water to see when it opens. you can also let the water cool and see when it closes. most honda thermostats are going to open around 170-180 deg F.</TD></TR></TABLE>
additional note to this gentleman's comments. If you pull your 'stat replace even if it works in the pot of water. It's a cheap part, replace it no mater what if you pull it.
Putting it in the water might give you indication if that was the problem.
Old Oct 24, 2005 | 08:20 PM
yeah, might as well. the thermostat and gasket wont put you out more than a tank of gas even for OE!
Old Oct 24, 2005 | 09:01 PM
92eg6's Avatar
my car warms up every morning, yes, but once i start driving with the heat on it goes back down to cold, or even if i allow the engine heat to be on it goes down...i never really tested to see how the hoses are, the water pump might cause this as well?
Old Oct 24, 2005 | 09:14 PM
BigJ5's Avatar
It does sound like your stat, but what are you running for coolant. If you run a larger mix of water to glycol, then heat will dissipate faster. when you do your stat, change your coolant with premix.
Old Oct 24, 2005 | 10:23 PM
bjbetty's Avatar
i had the same problem i added a little bit of power steering to my tranny and it lubed it up and started slippin into gears and warmed up my b16 cause some bastart pulled my tranny out in my sleep and took off the motor mounts and i couldnt fine them cause he hid them from me...what a jerk ..i found a donor motor that should be fine but it has been sitting in the bottom of a lake for a year...pleace help me i am just an inncont little man with a little plan
Old Oct 24, 2005 | 10:32 PM
Default Re: Car will not stay warm (bjbetty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjbetty &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem i added a little bit of power steering to my tranny and it lubed it up and started slippin into gears and warmed up my b16 cause some bastart pulled my tranny out in my sleep and took off the motor mounts and i couldnt fine them cause he hid them from me...what a jerk ..i found a donor motor that should be fine but it has been sitting in the bottom of a lake for a year...pleace help me i am just an inncont little man with a little plan</TD></TR></TABLE>
K, please tell me this is just someone BSing and joking around.
Old Oct 24, 2005 | 11:57 PM
.Grimace's Avatar
footwork mastery
say what??? thats in no way the same problem
Yoitshector
14
Jul 21, 2012 05:50 PM
aznlangjai
Oct 21, 2008 06:21 PM
chrislivesinpa
26
Feb 15, 2008 08:30 AM
Stevorh
13
Feb 2, 2005 04:06 PM
M0NEYnH0s
Dec 27, 2001 09:41 AM
