JDM B16 Pistons?
Old Oct 24, 2005 | 04:33 PM
BoostedEF's Avatar
Default JDM B16 Pistons?
Sorry guys I searched . I been out the scene for a while and Im trying to return my turbo car to stock i got a stock head already . The motor is a 1st gen jdm b16 with some 20 over pistons in it making it have 8.5:1 compression . My old mechanic told me to find a set of jdm 20over b16 pistons, these would be pr3 right ? Well if Im right can someone point me in the direction of where I can get some new pr3 20 over pistons complete with rings ?
Old Oct 24, 2005 | 04:46 PM
gsrious's Avatar
what you are looking for is p30 pistons.
Old Oct 24, 2005 | 04:50 PM
BoostedEF's Avatar
Default Re: (gsrious)
ok I found the p30 pistons in std bore or .25 Im assuming std bore is 20 over ?
Old Oct 24, 2005 | 05:23 PM
mmuller's Avatar
Mad Scientist
Default Re: (BoostedEF)
that means they are .25mm bigger
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEF &raquo;</TD></TR><TR><TD CLASS="quote">ok I found the p30 pistons in std bore or .25 Im assuming std bore is 20 over ?</TD></TR></TABLE>
Your assumption is incorrect.Standard is standard (81mm).Plus .25 (mm) is (81.25mm) or about .010".Twenty over would be +.50mm (81.50) or +.020".
Glenn
Old Oct 24, 2005 | 05:51 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">what you are looking for is p30 pistons.</TD></TR></TABLE>
He said he owns a first gen b16, in which case he is right to think pr3 pistons.
p30's will just make more power, and they are a hair lighter then the pr3's
GSR_EJ
Dec 23, 2009 04:33 PM
1993gsrcivic
Oct 3, 2007 11:31 AM
EFing8
Apr 3, 2003 10:32 AM
