How long should the fuel system stay pressurized?
Old Oct 24, 2005 | 02:34 PM
exvtec94's Avatar
Default How long should the fuel system stay pressurized?
How long should the fuel system stay pressurized after the engine is shut off?
On my 97 LS all OEM fuel components the fuel pressure only holds for 1-2hours on the fuel filter mounted pressure gauge. I have a rough(misfire) idle on semi cold startups and think its a leaky injector. NO CELS and #1 cylinder plug looks slighty rich compared to the other 3. I have moved the #1 injector over to #2 and will recheck the plug in a few days.
Old Oct 24, 2005 | 03:33 PM
Kito96LS's Avatar
Default Re: How long should the fuel system stay pressurized? (exvtec94)
1hr
Old Oct 24, 2005 | 03:48 PM
exvtec94's Avatar
Default Re: How long should the fuel system stay pressurized? (Kito96LS)
1hr at fuel pressure specs??
anyone else?
Old Oct 24, 2005 | 04:54 PM
loudassVTEC's Avatar
Mine does the smae thing, It'll start to drop off pressure after a few minutes, but it'll hold at around 20 PSI for about an hour. When I start the car the next day or later that day, it is at 0 PSI. I don't know if that's normal, but I don't have any problems, or missing of any sort.
Old Oct 24, 2005 | 05:16 PM
Devo94ac's Avatar
Default Re: How long should the fuel system stay pressurized? (loudassVTEC)
not really to sure on my psi but everytime i refuel the pressure sounds is crazy, everytime i refuel could be a few days before each time
Old Oct 24, 2005 | 07:02 PM
kuja's Avatar
my guage is mounted on my fpr, it drops off pretty quickly, isn't it just because the fuel goes back down the return ?
Old Oct 24, 2005 | 07:29 PM
exvtec94's Avatar
Default Re: How long should the fuel system stay pressurized? (kuja)
supposedly its supposed to hold pressure for some time.. need to know how long though..
anyone else with a fuel pressure gauge installed. check you cars after 1 hour 2 hour for fuel pressure please.........
Old Oct 24, 2005 | 07:46 PM
kuja's Avatar
hmph, well then mines fubar'd
Old Oct 25, 2005 | 12:13 PM
exvtec94's Avatar
fryman
Oct 21, 2009 02:39 PM
jman86
Aug 26, 2006 08:13 AM
BB6racer
Aug 25, 2006 09:19 PM
exvtec94
Oct 26, 2005 09:43 AM
se93
Dec 25, 2003 01:47 PM
