Tires down to the wires
Old Oct 24, 2005 | 01:59 PM
zerovandez's Avatar
Default Tires down to the wires
hi, I have a set of Dunlop FM-901's. My right front is showing major wear down to showing the wires in tire. I know it's due to bad toe as I havn't had time to adjust it. It's about 1/4 (or a little more) from the inside to out that is worn. From that 1/4 I'd say 25% (or less) is showing wire. Kinda dumb question but someone make me feel better, how long do you guys think I can last on that? I'm kinda pressed on cash so if anybody has a set of 205/45/16 tires around, let me know. Thanks.
Old Oct 24, 2005 | 02:01 PM
IHateJDM's Avatar
Default Re: Tires down to the wires (zerovandez)
go find a steelie and throw it in your trunk, you carry a jack, right?
Old Oct 24, 2005 | 02:47 PM
TurboEM1's Avatar
if you see the belts honestly you dont have much time left. if you need something cheap just go to a local tire place and see if they have used tires. This place by me is ghetto and you can get used tires and totally bargain with them. if your really tight on money you can get 2 fronts and just mount them. no balancing or anything. you should be able to get 2 fronts mounted for like $40. if you want them balanced or nicer tires then it gets more money but in a pinch it will definatly work and be much safer then something showing the belts.
Old Oct 24, 2005 | 03:18 PM
zerovandez's Avatar
koo, wuts this place called and location?
Old Oct 24, 2005 | 03:33 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (zerovandez)
used tires arent that great either, u never know where they have been or been through. I guess its cool to roll, on but be careful and work to get your real tires put on. A friend of mine frequents the use of used tires. One day on the freeway it blew and he spun out, luckily it was late so no one was really around. The tire didnt have the belts showing, he thouht it was good, so we dont know what happened, but he stays away from used now
Old Oct 24, 2005 | 03:46 PM
TurboEM1's Avatar
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">used tires arent that great either, u never know where they have been or been through. I guess its cool to roll, on but be careful and work to get your real tires put on. A friend of mine frequents the use of used tires. One day on the freeway it blew and he spun out, luckily it was late so no one was really around. The tire didnt have the belts showing, he thouht it was good, so we dont know what happened, but he stays away from used now </TD></TR></TABLE>
I totally agree. Use them only untill you can get new ones but they should be better then the ones with the belts showing.
Old Oct 24, 2005 | 04:07 PM
yoej8's Avatar
i had the same tires and actually wore it down to the wires too. not too sure if you been gettin rain up there in long beach, but be careful of hydroplaning.
Old Oct 24, 2005 | 04:28 PM
racekar711's Avatar
change it now. you'll pay more when you blow out on the freeway, buy a cheap spare for now
Old Oct 24, 2005 | 04:29 PM
dogbiscuit's Avatar
Falken Ziex are cheap tires and their really not all that bad for daily driving.
Old Oct 24, 2005 | 04:45 PM
dpkelly's Avatar
Default Re: (dogbiscuit)
Walmart tires are really cheap and quite reliable. Be careful if you're only replacing the fronts or just the rears. If the fronts and rears have different treadwear you'll get really bad wandering while driving in ruts. I'd say take transit for a month or two while your car's off the road without insurance until you save for a really good set of tires.
Old Oct 24, 2005 | 04:56 PM
old man neri's Avatar
Default Re: (dpkelly)
If a cop sees wires......you are in a world of hurt. Please change your tires before you get a blow out and hurt yourself or someone else.
Old Oct 24, 2005 | 09:20 PM
zerovandez's Avatar
Thanks for the tips guys, I have a old set of 15 inch FN01R-C's I get get by with. They'll last until i can get som tires. What do you guys think of BFGoodrich's Sport tires? They've gotten pretty good reviews at tire rack.
Old Oct 24, 2005 | 09:53 PM
Not to critisize but get some tires that are decent, will last a long time, and that are cheap.
Get the nice toys when you have the money for it. This is why I am running on 13" tires.
But that's my 2 cents.
Old Oct 24, 2005 | 10:00 PM
zerovandez's Avatar
well, as I mentioned in the first post...this is my fault. I should have gotten my allignment done. My toe was waaayyy off. So they could've been a cheap tire which were supposed to last a long time, but don't u think they would've worn out the same way these did under my condition?
Old Oct 24, 2005 | 10:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">well, as I mentioned in the first post...this is my fault. I should have gotten my allignment done. My toe was waaayyy off. So they could've been a cheap tire which were supposed to last a long time, but don't u think they would've worn out the same way these did under my condition? </TD></TR></TABLE>
Not really your fault, **** happens. I don't get an alignment done regularly. All it takes if for you to led your car to your buddy, he hits a curb and doesn't tell you and next thing you know you see wires.
All I was saying is maybe you should question the wisdom of riding on 17" tires if you can't afford to replace them. But you are right, it's none of my buisness, this is a tech forum and not an advice forum. Forget I mentioned it, spend your money as you so see fit.
-matt
Old Oct 25, 2005 | 07:23 AM
zerovandez's Avatar
Default Re: (old man neri)
You're totally right about "**** happens." That's why I can't get the 16" tires! Oh well, you made me feel better when you said it's not totally my fault. Thanks for that! My point was just to say, it wasn't the cost of the tire that caused the problem. Thanks for your replies though dude!
Old Oct 25, 2005 | 07:35 AM
JICEK9's Avatar
you are joking right? BUY TIRES BEFORE SOMETHING BAD HAPPENS
I can't believe it. there is officially a post on H-T about some jackass wondering how long he can drive on wires. can something this STUPID even be considered "tech"?
Old Oct 25, 2005 | 10:34 AM
zerovandez's Avatar
Default Re: Tires down to the wires (JICEK9)
Dude, calm down. I will replace the bad tire with a 15 inch 5zigen rim with good tire tread. I go to and from work about 3 miles each way. I understand the severity of this and being that I work 2 jobs I really don't have time to drop it off until this weekend. I agree, something like this is stupid and is not "tech." Yet I do want opinions and suggestions pertaining to my questions. And why do you have to call me a Jackass? LOL, so there are dumbasses on HT who like to "E-Bang" over the internet! Don't you have anything else better to do? So, to make YOU happy I will change the tire, yep just for you!
Cheers....
Modified by zerovandez at 10:55 PM 10/25/2005
Old Oct 26, 2005 | 06:04 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">So, to make YOU happy I will change the tire, yep just for you! Modified by zerovandez at 10:55 PM 10/25/2005</TD></TR></TABLE>
First of all, don't give me any bullshit about being to busy. Lemme guess, last week you had all the tread in the world, and now this week your wondering if you can make it to the weekend with wires popping out.
Seconed, don't ATTACK me because you are making a jackass decision. It is dumb to drive around like that. Think about driving down the freeway and to have a couple tires blow out. Your risking your car, your life, and most importantly the OTHER DRIVERs around you.
And it will make me happy to see you replace the rubber. Because even though I don't know you, I wouldn't want to see you die beacuse you didn't have time to change some tires. And don't street race either
Have a nice day
Old Oct 26, 2005 | 02:22 PM
zerovandez's Avatar
Thanks for the concern dude. I didn't mean to attack you but I felt attacked myself! I probably didn't have all the tread in the world last week
I had no reason to look under the car until this past Sunday to look for roadkill but instead I observed a messed up tire. I got around to putting on the 15inch Zigens last night with near perfect rubber wrapped around it but the tire directon is oposite (any problems here?)!. Then I got to observe the messed up tire more. It was actually not that bad. only a small portion was starting to show wire. The rest of it was just kinda bald. Still dangerous. But, JICEK9 thanks again for your concern, you even got me calling myself jackass that night!!
Old Oct 26, 2005 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">I got around to putting on the 15inch Zigens last night with near perfect rubber wrapped around it but the tire directon is oposite (any problems here?) </TD></TR></TABLE>
Yes, don't drive in the rain. especially seeing as you have now have different tires on different sides (car might start to really act funny)
But it is better then wires.
Old Oct 26, 2005 | 05:48 PM
o5mar1's Avatar
it sound more like a camber issue and not a toe usually toe dosent cause tire wear unless its excesive. all that toe cause is a steering wheel beign of center.
Old Oct 26, 2005 | 06:01 PM
Default Re: (o5mar1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o5mar1 &raquo;</TD></TR><TR><TD CLASS="quote">it sound more like a camber issue and not a toe usually toe dosent cause tire wear unless its excesive. all that toe cause is a steering wheel beign of center. </TD></TR></TABLE>
It cause part of my tire to go down once.
Old Oct 26, 2005 | 06:26 PM
VRD^sam's Avatar
yeap
Old Oct 26, 2005 | 06:49 PM
Targa250R's Avatar
be professional
You are partially or fully incorrect on all counts.
