HELP!! Integra won't start after clutch install?!!
Old Oct 24, 2005 | 12:58 PM
95greenteg's Avatar
Default HELP!! Integra won't start after clutch install?!!
Ok
my bro's friend intalled my new Exedy clutch this weekend on my DC2 and for some reason it does not start until after about 3 to 5 turns on the ignition....All I hear is a click when I try to turn the key on the ignition...What could be the problem?
Old Oct 24, 2005 | 01:10 PM
SlowReaction's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (95greenteg)
check the postive connetion on the the starter make sure the nut is tight.
Old Oct 24, 2005 | 02:14 PM
doublejz's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (SlowReaction)
make sure you didn't pinch a wire between the tranny and motor and also check the ground wire on the thermostat housing
Old Oct 26, 2005 | 12:48 PM
95greenteg's Avatar
Which one is the positive connection on the starter?
Old Oct 26, 2005 | 12:59 PM
putitinthebucket's Avatar
did u reground the tranny to the chassis???
Old Oct 26, 2005 | 01:04 PM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (putitinthebucket)
Why do you ask? Where is the ground from the tranny?
Old Oct 26, 2005 | 01:08 PM
there should be a ground wire going from the passenger side frame rail to the top or side of the tranny . When i reinstalled my first tranny it did the same thing and thats what it was on my car. Did you make sure the battery didnt discharge
Old Oct 26, 2005 | 01:12 PM
95greenteg's Avatar
I don't know cause I didn't do the work...My brother's frined did...
Old Oct 26, 2005 | 01:13 PM
95greenteg's Avatar
Is the grund you're referring to the one on top of the starter? If so, I checked that and it seems to be a good connection...
Old Oct 26, 2005 | 04:26 PM
95greenteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by putitinthebucket &raquo;</TD></TR><TR><TD CLASS="quote">there should be a ground wire going from the passenger side frame rail to the top or side of the tranny . When i reinstalled my first tranny it did the same thing and thats what it was on my car. Did you make sure the battery didnt discharge
what do you mean by discharge?
Old Oct 26, 2005 | 05:35 PM
Evil-EK's Avatar
The ground everybody is refering to goes between the frame rail (right above the tourqe mount) to a bracket on the tranny. Make sure both ends are connected properly.
Old Oct 26, 2005 | 06:21 PM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote">The ground everybody is refering to goes between the frame rail (right above the tourqe mount) to a bracket on the tranny. Make sure both ends are connected properly.</TD></TR></TABLE>
thanks...I'll check tomorrow...
Old Nov 6, 2005 | 06:03 AM
95greenteg's Avatar
YES!!!! Finally fixed my car! Did the starter rebuild from the articles section on Team-Integra.com and BAM! It starts like a dream! I'm excited cause I saved over $100 by doing this...Big shouts to fast95se on T-I for discovering this
Old Nov 6, 2005 | 07:41 PM
BLUE EH3's Avatar
Help we my pennies
can u post how!!
Old Nov 6, 2005 | 07:45 PM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (BLUE EH3)
Go to team-integra.net and look at articles to see how to do it...
Old Nov 7, 2005 | 06:43 AM
dinko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenteg &raquo;</TD></TR><TR><TD CLASS="quote">Go to team-integra.net and look at articles to see how to do it...</TD></TR></TABLE>
wow useless. maybe this hasn't crossed your mind yet but people come to honda-tech to help eachother out with TECHNICAL problems. you had a problem, and you fixed it...now post how u did it incase somebody uses the SEARCH button and come across your thread, they can look inside for the solution in case they have the same problem.
****** a
Old Nov 7, 2005 | 01:32 PM
95greenteg's Avatar
Default Re: HELP!! Integra won't start after clutch install?!! (niann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niann &raquo;</TD></TR><TR><TD CLASS="quote">
****** a</TD></TR></TABLE>
Why do you have to ba a pain in the ***...The time you took to write all that BS you could've used to post the DIY yourself...Besides, someone had already posted this info on here before...Anyways, i will go ahead and give you the link for you lazy asses out there...
http://www.team-integra.net/se...=1079
p.s. I had already included the link in my other thread in the Integra section I just didn't have time to add the link here...
All you gotta do is just SEARCH.
92eg6_pino
Oct 9, 2010 04:56 PM
whokid_911
24
May 8, 2010 12:49 PM
Dc2phil
Mar 3, 2010 09:59 AM
stockegsix
Oct 18, 2007 10:21 AM
hondatechguy25
Mar 11, 2007 04:51 AM
