what radiator to get?
Old Oct 24, 2005 | 12:33 PM
typeRobtypeS's Avatar
Default what radiator to get?
my current setup is a 94 integra gsr turbo. i was wondering what radiator would be the best to get. i was going to put a koyo radiator in but theres no way i could get it to fit with my manifold and wastegate in the way. Should i just get a oem honda radiator like maybe a del sol? and also which radiator cap would i want to use? let me know, thanks.
Old Oct 24, 2005 | 12:37 PM
5 Speed AP2's Avatar
Default Re: what radiator to get? (typeRobtypeS)
OEM has been working fine for me.
As far as a radiator cap, depends on how much bling you want the cap to give.(spoon,apex,etc etc)
Old Oct 24, 2005 | 12:44 PM
Default Re: what radiator to get? (5 Speed DC2)
should it be a 1.3 cap or does it depend on which radiator i go for?
Old Oct 24, 2005 | 01:15 PM
1.1 is stock. Most aftermarket ones are 1.3.
Stock will do just fine.
Old Oct 26, 2005 | 03:05 PM
would a koyo del sol radiator fit in an integra with no problem? if so would that be a better idea?
Old Oct 26, 2005 | 03:27 PM
Rahxephon's Avatar
fluidyne or koyo....i have fluidyne
Old Oct 26, 2005 | 04:04 PM
Default Re: what radiator to get? (Rahxephon)
would it be better to get like an koyo oem or an aluminum. the aluminum is probabily more expensive im guessing
Old Oct 26, 2005 | 04:06 PM
Wayne_Curr's Avatar
When my radiator blew up (in front of starbucks, totally sprayed their window with coolant it was awesome =D) I got a new one off radiatorbarn.com. Its an aluminum 2row radiator (really no wider than OEM) and was 125 including shipping. Been workin real well cooling my engine since...thats my suggestion.
Old Oct 26, 2005 | 04:20 PM
Default Re: what radiator to get? (Wayne_Curr)
well right now i kinda have to get a koyo since im returning the one that i already have and its too late to get cash back. so i can only exchange for another koyo.....
Old Oct 26, 2005 | 05:19 PM
00IntegrAllmotoR's Avatar
HT Black OPs
get a half size no matter what brand you go with since your having fitment issues. and then maybe you could get a nice pusher fan too. just a suggestion.
Old Oct 27, 2005 | 12:02 PM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">When my radiator blew up (in front of starbucks, totally sprayed their window with coolant it was awesome =D) </TD></TR></TABLE>
so that's where they got the idea for the green tea frap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">get a half size no matter what brand you go with since your having fitment issues. and then maybe you could get a nice pusher fan too. just a suggestion.</TD></TR></TABLE>
it's true! here's a pic of my custom-i-zation. i have an oem civic half size, dual core automatic with a pusher fan from b18bturbo. (picture is puller style fan, i installed it incorrectly there. lol) but i just smashed the old bracket piece flat to hold the top. and zip ties own
i know phoenix turbo has a deal for some half size dual core pwr radiators.
i would recommend an aluminium radiator, although the stock ones do work. but if you're going turbo, think about the setup you want and go with a radiator to work with it. most equal length manifolds require half size radiators.
Old Oct 27, 2005 | 12:20 PM
redDAinteg's Avatar
Default Re: what radiator to get? (undercoverdc2)
radiatorbarn.com alot thicker than stock also.
Old Oct 27, 2005 | 12:24 PM
rdeezy78's Avatar
Default Re: what radiator to get? (00IntegrAllmotoR)
I agree. you definitely want to go with the half rad. Good luck
Old Oct 27, 2005 | 06:33 PM
DCnotTHEshoes's Avatar
fluidyne?
Old Oct 27, 2005 | 07:37 PM
D-t's Avatar
D-t
Default Re: what radiator to get? (DCnotTHEshoes)
What about if I have a/c? Could I still just use a half size radiator with only 1 pusher fan?
This is for an LS. I was thinking going with a Del Sol half size dual core from b16a del sol's with a pusher fan? For a boosted setup.
Old Oct 27, 2005 | 09:37 PM
TheBobFather's Avatar
Default Re: what radiator to get? (D-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-t &raquo;</TD></TR><TR><TD CLASS="quote"> What about if I have a/c? Could I still just use a half size radiator with only 1 pusher fan?
And how about a slim one for the a/c
Old Oct 27, 2005 | 09:56 PM
cnaman's Avatar
arent all fans "puller" style?
i mean, why would they make a fan that pushes air from the engine bay out thru the radiator?
makes no sense to me.
Why no go with the flow of air when ur car is moving forward?
seems kinds retarded if ur driving and is coming is from the front, while the fan is trying t push hot air out?
can u peeps please correct me if im wrong?
by the way, get a koyo all metal radiator or Modine all metal radiator. I have a auto Modine all alumnium radiator for sale. used but it good condition. its black and looks stock. About the same size as a Denso Radiator.
Modine all aluminum radiator goes for 130. i'll sell it for 80 shipped.
Old Oct 27, 2005 | 10:02 PM
Default Re: (cnaman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnaman &raquo;</TD></TR><TR><TD CLASS="quote">arent all fans "puller" style?
Correct me if im wrong.........but the pusher is on the bumper side pushing air towards the motor, and the puller is on the motor side, also pushing towards the motor.
Old Oct 28, 2005 | 01:11 AM
riceball777's Avatar
Modine all aluminum radiator goes for 130. i'll sell it for 80 shipped.</TD></TR></TABLE>
a puller and pusher both blow air into the engine bay
a puller is like the stock fans which mount like stock and pull air into the engine bay
a pusher mounts on the other side and pushed air through the radiator and into the engine bay
i would get a thicker aluminum hald size radiator. i see way too many ppl with turbos that over heat with stock civic half size raditor. i really dont think oem half sizes are good for turbos. just spend the 300 and get a good name brand aluminum one if your going to boost
CivicSweetie01
Honda Civic (2001 - 2005)
May 20, 2011 01:44 PM
charms119
Jun 19, 2005 07:48 PM
MugenT
Jun 3, 2005 03:23 PM
MaxSterling
Jun 30, 2003 09:51 PM
speedaholic92
Oct 28, 2002 04:31 AM
