low end power loss
I changed the timing belt on my Civic, when firing it up again, it took a bit of trying,but it started up, idles fine, but now it is a dog going up hills. No spunk at the low RPMs. Seems to run fine in the high end power band. Any suggestions?
I have done a compression check to see if any damage occurred when the belt broke, but it does idle fine and has normal power once you are up over 300rpms
Modified by kpringcivic at 2:44 PM 10/24/2005
Doom325
Apr 24, 2005 04:54 PM
