D15B Replacement Parts(Sorry if I didn't find this in my searching)
I have searched and I am sorry if I did not find this. I am rebuilding my JDM D15B. I am really trying yo find out if replacement parts(oil pump, water pump, timing belt, gasket kits, etc)are the same across the board. Any USDM D15 gasket kits and such will work on this motor. Timing belt from a d16z6. As well as the clutch kit. Also any good places to find these parts. any good sites things like that. I used to have a site with a good price on clutch kits but I can't find it anymore. Please help if you can. Thank you in advance.
I think you should use the timing belt from a vx which has 103 teeth. The water pump from a vx should transfer over as well. When i did my swap i got my belt from autozone for about 30 bucks.
i dont know if the vx and dx are the same but i used a dx timing belt. The d16Z6 definetely wont work but if i remember correctly the water pump did.
Well I am looking for something a bit more definate. If anybody knows for sure what will and will not work I really need to know. Thank you.
Well when motor is back together I will pick up the timing belt. I still would like info on the other parts. Thanks guys
Bump for this poor man, common people with D15Bs help a brother out. Sadly that is the reason why I chosed a ZC Vtec instead of the D15B. Good Luck with your search
I know this is going off topic slightly. But, what would you say with forged pistons, rods, and rings; that this motor is capable in the ways of boost. I am hoping for 13-16 psi with CR in the mid 8's? I appreciate any help that can be offered.
dookeye
Dec 27, 2008 09:06 AM
SC0TT
Aug 3, 2002 04:44 PM
