a/c problems
Old Oct 24, 2005 | 05:46 AM
acourt's Avatar
Default a/c problems
a/c would blow cold for 10 minutes then blow only warm air, a/c would consistently do this for past couple years(car is only driven rarely as it is not my main ride), so i finally I took the 1991 crx si to a reliable honest shop and they thought the ecu was not sending a signal to keep compressor on, so they had ecu rebuilt($400),also the rebuilt ecu did not solve problem so the honda shop did not charge me for labor or parts,now compressor does not come on at all. They sort of gave up on it so does anyone out there have any ideas?
Old Oct 24, 2005 | 06:05 AM
eda6's Avatar
Default Re: a/c problems (acourt)
sounds like you have a refrigerant leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acourt &raquo;</TD></TR><TR><TD CLASS="quote">they thought the ecu was not sending a signal to keep compressor on</TD></TR></TABLE>
compressor dropped out on lo pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acourt &raquo;</TD></TR><TR><TD CLASS="quote">now compressor does not come on at all</TD></TR></TABLE>
System is probably flat, lo pressure swich is still open.
Pull the cap off the access port and depress the valve. Is there pressure?
Old Oct 24, 2005 | 06:13 AM
acourt's Avatar
Default Re: a/c problems (eda6)
thanks ill try that,someone else also thought it couil be the thermostat,any comments on that?thanks
vader007
Nov 8, 2022 07:25 PM
LsVtecFoti
Apr 20, 2008 11:23 PM
ej2civic
Jun 18, 2007 07:32 AM
renton
Honda Civic (2006 - 2015)
10
May 30, 2007 03:51 PM
THEUSED
Mar 12, 2006 01:30 PM
