Programming remote entry keyfob / 2003 Accord EX
Old Oct 24, 2005 | 04:27 AM
jdoz22's Avatar
Default Programming remote entry keyfob / 2003 Accord EX
Does anyone have a procedure, or can point me to a procedure, for re-programming the keyfob on a 2003 Accord EX? I'd like to save a 2-hour trip to the Dealership if possible, and it is not in the manual.
Thanks
Old Oct 24, 2005 | 08:27 AM
JimBlake's Avatar
Default Re: Programming remote entry keyfob / 2003 Accord EX (jdoz22)
This is for '98 & '99, but I think it's the same.
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
Old Oct 27, 2005 | 11:38 AM
jdoz22's Avatar
Default Re: Programming remote entry keyfob / 2003 Accord EX (JimBlake)
Thank you so much, it worked like a charm on my 2003 Accord EX.
My warranty is up in a few days, hopefully this vehicle will last a long time
Old Oct 19, 2023 | 12:24 PM
Pay7Tay5!!'s Avatar
1) Unlock Doors
8) on position
9) lock or unlock
10) off position
11) on position
One question I have to keys one key starts it and the other key just unlocks it only b the unlock bottoms on the key fob and that key fob want unlock the door b the key n the door don't have a key for the door so which key do I use to do these steps
porkchop13
Jul 15, 2017 03:41 PM
bhauen
Jun 11, 2015 07:27 PM
jsquared22
Oct 28, 2006 12:47 AM
-=DFOX=-
Jun 15, 2005 03:13 PM
Mr.Speed
May 26, 2005 10:18 PM
