molding and repairing urethane???
Old Oct 24, 2005 | 04:08 AM
morepoop4u's Avatar
Default molding and repairing urethane???
Does anybody have any tips or links on working with urethane. I want to make a custom real time racing style front lip using a ww itr lip.
before
after ps
thx to whoever these cars belong too.
some 3m products
http://products3.3m.com/catalo..._html
Old Oct 24, 2005 | 08:51 AM
beepy's Avatar
Default Re: molding and repairing urethane??? (morepoop4u)
I have never tried molding urethane, because I am pretty sure it is a vacuum molding process. But repairs are easy. Grab a "urethane bumper repair kit" at NAPA, most of them sell it. It consists of two tubes to be mixed 50/50 which can then be treated like Bondo. It's how I molded an IROC air dam onto my '79 Camaro.
Old Oct 24, 2005 | 08:53 AM
.swanny's Avatar
Your best bet would be to find another chunk of urethane from an old bumper, cut it to size, sand it with some 80 grit paper, use the adhesion promoter (if the product you're using has one) and then use some sort of 2 part epoxy or bonding agent. Your local auto body supply store should carry either 3m, duramix, fusor, or kent products. Tubes of this aren't cheap, usually around 40+ dollars a tube and about a dollar for each mixing tip. Hopefully they will have the 2-part gun available for rental. After you get the patch bonded on use some flexible glazing putty, sand to contour, prime, etc.
If you have any more questions feel free to shoot me a PM.
Old Oct 24, 2005 | 09:17 PM
morepoop4u's Avatar
Default Re: molding and repairing urethane??? (.swanny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .swanny &raquo;</TD></TR><TR><TD CLASS="quote">Your best bet would be to find another chunk of urethane from an old bumper, cut it to size, sand it with some 80 grit paper, use the adhesion promoter (if the product you're using has one) and then use some sort of 2 part epoxy or bonding agent. Your local auto body supply store should carry either 3m, duramix, fusor, or kent products. Tubes of this aren't cheap, usually around 40+ dollars a tube and about a dollar for each mixing tip. Hopefully they will have the 2-part gun available for rental. After you get the patch bonded on use some flexible glazing putty, sand to contour, prime, etc.
If you have any more questions feel free to shoot me a PM. </TD></TR></TABLE>
Yah that's what I was thinking. I was going get a scrap teg front bumper and trim it at the bumper line so i have the basic contour. then mold it to the bottom of the itr lip and mount a front splitter.
fixi
Aug 10, 2005 02:02 PM
pr_tony_montana
Nov 13, 2004 03:52 PM
Hoosier Daddy
Dec 24, 2003 11:08 AM
zer0zer0 TypeR
Jan 28, 2003 03:46 PM
Maximus
Aug 8, 2002 11:31 PM
