Honing a B16 for OEM rings.
Old Mar 7, 2002 | 07:57 AM
EKhatch's Avatar
Default Honing a B16 for OEM rings.
Hey guys, I am building a B16 with oversized CTR pistons and using OEM Honda rings. My machine shop wants to know what grit of finish to put on the cylinder walls when they hone it. Does anyone know the answer or where I could find it?
Thanks
Old Mar 7, 2002 | 08:04 AM
WAFFLES's Avatar
Default Re: Honing a B16 for OEM rings. (EKhatch)
I would think if your machine shop doesn't already know that, you should go somewhere else. I don't know what you need to use, but I'm no machinest. I know the place I go already knew what to use.
Old Mar 7, 2002 | 08:35 AM
EKhatch's Avatar
Default Re: Honing a B16 for OEM rings. (WAFFLES)
Well like many places in Idaho this machine shop has never worked on a B16 before. If I bring them the rings they will be able to make an educated decision but they want to know what finish Honda uses from the factory(just as a fail safe) since the rings are OEM.
Old Mar 7, 2002 | 10:34 AM
B18C-EJ1
Guest
Posts: n/a
SERIOUSLY!!
Old Mar 8, 2002 | 09:26 AM
ysrhatch's Avatar
New User
Default Re: Honing a B16 for OEM rings. (B18C-EJ1)
if the machine shop is asking you a question in which you assume they would already know, then dont have that shop work on your block. its only common sense dude.
Old Mar 8, 2002 | 11:20 PM
KayOs's Avatar
Hone cylinder bores with honing oil and a fine (400 grit) stone in a 60 degree cross-hatch pattern. If the machine shop doesn't already now this then I would be very careful with measuring proper clearances.
Kaleb
Feb 5, 2012 12:51 PM
Je8021
14
Jul 11, 2010 01:59 AM
roadsqueegy95
Jul 2, 2009 06:23 PM
neutron91
17
Aug 28, 2005 07:32 AM
