koni yellows for em2, 50mm and 55mm diameter?
Old Oct 23, 2005 | 10:52 PM
JTTeG_X's Avatar
Default koni yellows for em2, 50mm and 55mm diameter?
theirs 2 different set of koni yellow struts for the 2001-2005 honda civic coupe/sedan. Koni-na says theirs a 50mm and 55mm version on the outer diameter housing on the OE strut. how do i go about measuring which one i have?
Old Oct 24, 2005 | 01:29 AM
civicvtec1ps's Avatar
Default Re: koni yellows for em2, 50mm and 55mm diameter? (JTTeG_X)
2001-02 used 50mm
03+ use 55mm
Old Oct 24, 2005 | 07:06 AM
kung fu grip's Avatar
not true.
my '03 had 50mm. i've read posts about some cars have a 50mm on one side, 55 on the other.
you need to borrow a caliper to measure the diameter of your front strut bodies.
home depot or lowes also sells plastic measuring calipers for $1-2.
Old Oct 24, 2005 | 08:45 AM
ojay's Avatar
Default Re: (kung fu grip)
http://www.7thgencivic.com/for...40940
measure it.
Old Oct 24, 2005 | 08:58 AM
another way to do it:
buy a set of used front struts (or all four). i think i bought mine including the entire assembly (upper mount, etc) for $50. i measured those when they came, bought the konis and reassembled them. it made the changeover really easy.
Old Oct 24, 2005 | 11:25 PM
JTTeG_X's Avatar
i cant visit 7thgencivic.com , some reason my router doesnt let me go their...not even the homepage.
but how do i go about measuring this specific size? exactly what part of the strut am i measuring and what components do i have to remove from my vehicle to do so?
can someone post a photo thats not linked to 7gc.com?
thanks
Old Oct 25, 2005 | 04:18 AM
Default Re: (JTTeG_X)
you don't have to remove it. you might have to jack up the corner and remove the wheel, tho.
here's where you measure:
Old Oct 25, 2005 | 12:19 PM
JTTeG_X's Avatar
thanks a lot kung fu grip, btw, thats an strut assembly off an em2/es1? never knew it was THAT short.
now where can i find a tool that can wrap around that bar to measure this?
and how do i go about the rears? are they direct replacements or do i have to measure those too?
Old Oct 25, 2005 | 12:58 PM
you can use a vernier caliper like this one (click)
Old Oct 25, 2005 | 02:52 PM
JTTeG_X's Avatar
hold up, how am i suppose to measure the diameter with a flat ruler? or am i measuring how wide it is? if im correct, that part where you measure is a circle or is it oval?
Old Oct 25, 2005 | 06:25 PM
ojay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flotsamm@7thgencivic.com &raquo;</TD></TR><TR><TD CLASS="quote">There are only two sizes for the front strut, 50mm and 55mm. When I questioned Koni about which ones I needed, they said that in 2002 Honda mixed them up so you could have either size and its best to measure before buying. The easiest way of the use a dial caliper like this one and measure the diameter like mentioned above:
I had one that I bought for 12 bucks from my local hardware store. If you dont have one, this is what Koni said to try:
Take a piece of string and wrap it around the strut to get the circumference. Then take the circumference and divide it by 3.14(pi) to get the diameter. Use the diameter you come up with the order the right one.
This is what I came up with when doing my math using this method:
If the string measures 157mm, then divided by 3.14 you get 50mm
If the string measures 172mm, then divided by 3.14 you get 55mm
Someone please correct me if my math is wrong thx. Thank goodness I had a dial caliper heheh. Anyways, you most likely will have the 50mm fronts. When I ordered mine from Rob at Robbear Racing he said that he never had any problems with fitment. Also I believe that the 55mm ones are the stock size in the RSX, but could have been used in some Civics.
About being loose, you could indeed have the wrong size, or it could be that you cut to much off the strut housing. The small bumps on the insert are supposed to be inside. The instructions say to measure 40mm from the top and then make your cut, like this:
If you cut to much off the bumps on the insert wont press against the inside of the housing and the top of the insert will be loose and rattle. What I did to be on the safe side is just cut off 30mm. I'd go and measure it to find out which size you need.
Old Oct 25, 2005 | 09:18 PM
JTTeG_X's Avatar
so as for konis words, the 2001 carry the 50mm, while the 2002 carries both 50/55mm while 2003+ carrys the 55mm?
hm? im gonna have to call koni and verify something
thanks for the DIY link ojay (i miss 7thgen )
Old Oct 26, 2005 | 06:20 PM
ojay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTTeG_X &raquo;</TD></TR><TR><TD CLASS="quote">so as for konis words, the 2001 carry the 50mm, while the 2002 carries both 50/55mm while 2003+ carrys the 55mm?
thanks for the DIY link ojay (i miss 7thgen )</TD></TR></TABLE>
get your router/firewall fixed,
estes0122
May 4, 2010 06:58 PM
swoosher21
Jan 11, 2005 04:40 AM
-slow ej-
Sep 17, 2003 04:39 PM
GreenBean
10
Apr 24, 2003 07:18 PM
AEGEAN
17
Dec 5, 2002 12:15 PM
