ECU - A/F Setup
Old Mar 7, 2002 | 07:08 AM
Guitarzann's Avatar
Default ECU - A/F Setup
I have a 93sol Si... and need a hand with hooking up the A/F gauge from autometer. Right now the violet wire coming from the gauge is running into the white wire coming from the ECU.
Is this correct? it's not giving me a correct signal.
Old Mar 7, 2002 | 07:35 AM
Hard2Find's Avatar
Default Re: ECU - A/F Setup (Guitarzann)
if its OBD I p30 ecu, there is alot of white wires there (i think about 3) just go to hybrid site and get the pin-outs
good luck
Old Mar 7, 2002 | 10:21 AM
JKim0901's Avatar
Default Re: ECU - A/F Setup (Hard2Find)
the purple with goes to d14 on the ECU.
Old Mar 7, 2002 | 12:42 PM
dogpile5's Avatar
25 Year Member
Default Re: ECU - A/F Setup (EH2_Hatch)
sometimes it is a white/grey wire. depending on where it was manufactured. my civic is canadian, and a couple of the wire colors are different. but the pin locations are always the same. check the pin, then make sure you have good power and ground for the gauge!
PhantomX
Jun 4, 2006 12:37 AM
.H22 POWER.
Apr 17, 2005 07:12 PM
boostng r
Sep 18, 2004 10:57 AM
0 0 0
Oct 16, 2003 12:15 PM
