93 injectors with pr3
good i got that out of my head. but get this they will work fine when i pour gas into the intake manifold they start working but with out it it doesnt get signal from the ecu. i hooked up the tester and nothing
91 hatch. it wouldnt start. i had spark so i was guessing no fuel but i had fuel at the return line. so i put some in the manifold to make sure i was right and started right up. it will run fine after i do that but it wont send signal to the injectors when cranking i checked it with my injector tester.
im probably just going back to the resistor box kind. too much of a hastle. the car use to be dpfi i thought i fucked up with the wiring for the cylinder position sensor but its correct, i thought it wouldnt know wich cylinder to inject if it didnt' know which cylinder it was at but thats just used for spark right? i still dont get why it would not send a signal to the injectors when cranking. it did seem to easy when i wired up the injectors to the harness. so your telling me i cant use those injectors with that ecu right?
labtec
Jun 11, 2007 07:54 AM
beef-cake
Jan 23, 2007 08:10 PM
n2oef
Jan 21, 2005 12:54 AM
