head bolt torque on b18c1?
Old Oct 23, 2005 | 07:19 PM
g1zcteg's Avatar
Default head bolt torque on b18c1?
hey whats up, im doing a head gaskets on a gs-r and was wondering if anyone had the torque specs on the head bolts also does anyone know if the stock bolts are torque to yield or if i can use the same bolts again? thanks
Old Oct 24, 2005 | 08:16 PM
g1zcteg's Avatar
Default Re: head bolt torque on b18c1? (g1zcteg)
anyone know?
Old Oct 25, 2005 | 04:57 PM
tasco's Avatar
60 ft pounds
Old Oct 25, 2005 | 04:59 PM
tasco's Avatar
Default Re: head bolt torque on b18c1? (tasco)
oh and yeah you can use the same bolts
Old Oct 25, 2005 | 07:17 PM
g1zcteg's Avatar
thanks
Old Oct 25, 2005 | 10:39 PM
shamoo's Avatar
Will you make something up for me please?
You have to torque them in a two step sequence. Of course, you also do this in a criss-cross pattern too.
First tighten them to 23 ft-lbs. Then tighten them again to 63 ft-lbs.
Old Oct 26, 2005 | 11:21 AM
HONDA RR's Avatar
Default Re: head bolt torque on b18c1? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">You have to torque them in a two step sequence. Of course, you also do this in a criss-cross pattern too.
First tighten them to 23 ft-lbs. Then tighten them again to 63 ft-lbs. </TD></TR></TABLE>
yup
spazman2099
Nov 30, 2014 10:24 AM
xDicktonesx
May 1, 2007 11:35 AM
NoLipRacen
Jan 24, 2004 11:38 AM
NOOTRON20
Oct 11, 2003 10:18 AM
Four Door LS VTEC
Feb 13, 2003 05:13 PM
