bfg gforce sport kwd2
hey are these tires any good?
i was thinking about getting them because they seem to be the best for the size i need which is 215/40/18
any feedback or suggestions please
also where is the cheapest place to get tires? tirerack?
Wow! That's too big even for the front of an NSX. Aren't you concerned over the fact that the larger diameter will make your car accelerate slower? A much better match for a fourth generation Prelude (which came with stock 205/55-15 tires) is 215/35-18, and there are LOTS more tires (and better tires) available in that size. For example, the Kumho Ecsta MX is $121 in 215/35-18, and offers MUCH MUCH better performance than the T/A KDW 2 for the same money.
Getting back to your original questions, the BFGoodrich g-Force T/A KDW 2 is an okay "budget performance tire", in the same category as the Yokohama ES100 and the Avon Tech M500. I don't normally recommend it because it's significantly more expensive than those other tires, with similar performance (or, offers lower performance than top-of-the-line tires that are similarly priced, like the Goodyear F1 GS-D3). But you have limited choices in the odd 215/40-18 size, and that's one of the few available.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy »</TD></TR><TR><TD CLASS="quote">where is the cheapest place to get tires? tirerack?</TD></TR></TABLE>
In the States, the first two places to check are Tire Rack and Discount Tire, as well as onlinetires.com, which sells Toyo tires (and other brands). Since you're in Canada, it might also be worth checking places on your side of the border, which will cut down on shipping as well as import duties, so you might check out 1010tires and TireTrends, both of which are in BC (you can probably buy at either place in person and avoid shipping charges altogether), as well as Talon, at the other end of your country. Shop around, check out prices as well as shipping costs and sales taxes and import duties...
Modified by nsxtasy at 1:42 PM 10/24/2005
I just did a little web browsing and found decent prices from Vancouver-area dealers on two different tires in the proper 215/35-18 size for your Prelude that will give MUCH better performance than the KDW 2:
Toyo T1R 215/35-18 CDN184.99/tire (around USD156) from 1010tires.com in Richmond
Kumho Ecsta MX 215/35-18 CDN199.95/tire (around USD168) from TireTrends.com in Maple Ridge
I would choose the Toyo over the Kumho; it offers slightly better performance for slightly less money. (That's an awesome price, too!)
These prices are slightly higher than prices in the States (USD148 for the Toyo from onlinetires, USD121 for the Kumho from Tire Rack), but the savings would probably be wiped out by shipping charges. Any time you can get good prices from a local place and not pay for shipping, it's worth considering.
I assume you are not planning to use any of these tires on snow or in frigid cold. All of these tires are summer tires and won't do well in those conditions. If you're planning to use the tires in winter, then you should either get an all-season tire, or a separate set of winter tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy »</TD></TR><TR><TD CLASS="quote">alright thx
the only reason why i don't want the 215/35 tires is because my car will be WAY too low.....</TD></TR></TABLE>
Then modify the suspension to reduce the lowering. Oversized tires is a very bad way to raise the height of your car, because it hurts acceleration, hurts handling, and throws off the speedometer and odometer.
im on koni yellows and eibach springs (pro kit) i am only lowered 1.2 front and 1.0 rear
any less lowering then that and ill have too much wheel gap
225/35 will be fine too and its really not that much bigger.
well i went to 1010tires in richmond locally and they said the prices are low on the site only because the prices for shipping are a lot higher so it evens out and they want 350 a pop for the toyo t1r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy »</TD></TR><TR><TD CLASS="quote">well i went to 1010tires in richmond locally and they said the prices are low on the site only because the prices for shipping are a lot higher so it evens out and they want 350 a pop for the toyo t1r</TD></TR></TABLE>
Doesn't sound very customer service oriented of them.
So have them ship you the tires...
BrutalDawg
12
Jan 13, 2005 06:20 PM
