Will b16 pistons fit on ls rods and drop in ls block without any machine work?
PR3's (10.8-1) and P30's (11-1) fit without modification, PCT's (CTR's) (12.3-1)?need slight modification to the small end of the rod or the piston to fit. The compression ratio of the CTR's in the B18A/B block has beed debated much and it seems that 12.3-1 is the general consensus, but I am not positive on this ratio.
