My radio says code !?!?
Old Oct 23, 2005 | 02:41 PM
T-78RX7's Avatar
Default My radio says code !?!?
My radio say code and wont let me listen to the radio or tapes? every once and a while it makes a beep noise. Any of you know how to fix this or what it means?
Old Oct 23, 2005 | 03:26 PM
JunTec's Avatar
Default Re: My radio says code !?!? (T-78RX7)
Yes! all you have to do is check the registration number in the top of the sterio...
Then call the Dealer and tell them you need the code...
Then they will ask you for the registration number in exchange for the code...
Now all you have to do is simply put in the code...
Done...
And every time you disconnect your sterio from power...like if you disconnect the battery, it will need a code for theft perposes...
Old Oct 23, 2005 | 03:28 PM
Sliced Beard's Avatar
Default Re: My radio says code !?!? (JunTec)
either that or you can just post up the seriel number and i will get you the code
Old Oct 23, 2005 | 03:29 PM
cxSHOE's Avatar
use serial number on radio. call dealership.. write down numbers they give you. put key in ignition, turn it once. turn radio on, punch in numbers .... whola!
and dont get fooled into thinking you will be charged for the code... if they do, ask to talk to the service manager...
if you run into any problems look in the alarm/radio section theres a guy there who can get you the code free of charge
Old Oct 23, 2005 | 04:36 PM
Default Re: My radio says code !?!? (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">if you run into any problems look in the alarm/radio section theres a guy there who can get you the code free of charge</TD></TR></TABLE>
I just threw the offer out of getting the code for him. I work for Honda and I have access to all of their computer systems and information retention systems
Old Oct 23, 2005 | 05:19 PM
neutron91's Avatar
if you take your car in there and there is no serial number on the door jamb or in the glove box you will be charged 1 hour labor... they shouldnt charge you if you have the serial number beforehand though... the reason they charge you is for the labor of taking the radio out
Old Oct 23, 2005 | 05:24 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: My radio says code !?!? (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">if you take your car in there and there is no serial number on the door jamb or in the glove box you will be charged 1 hour labor...</TD></TR></TABLE>
again, refer to dirtysol's post... does anyone read anymore?
Old Oct 23, 2005 | 06:52 PM
T-78RX7's Avatar
Default Re: My radio says code !?!? (Rodney)
Thanks guys the activation code was written on the bottom of the radio, I guess the guy before me had the same problem.
mrpena
May 4, 2017 03:07 AM
Drtbiker103
Acura TL, RL & ZDX
Dec 26, 2009 04:07 AM
Iomega01
Aug 10, 2005 06:18 PM
