88 integra revving
Old Oct 23, 2005 | 02:41 PM
88teg22's Avatar
Default 88 integra revving
just bought an 88 integra and it is hitting 1500 rpms when idling in neutral and then dropping down to about 500...it continuously does this back and forth..but when i turn on the a/c it stops and idles at 1000...how do i fix this?
Old Oct 23, 2005 | 02:45 PM
veggiemaster's Avatar
Default Re: 88 integra revving (88teg22)
have you checked the Idle Air Control Valve or the Fast Idle Thermo Valve? those are usually the 2 most common things that attribute to that kind of revving. Another could be a vacuum leak somewhere.
Old Oct 23, 2005 | 04:35 PM
88teg22's Avatar
Default Re: 88 integra revving (veggiemaster)
well the ecu is flashing red..which is o2 sensor right...but the o2 sensor is fine...it also seems to be running rich when it revs back and forth
Old Oct 23, 2005 | 07:33 PM
Jose-aka-Pedro's Avatar
lol,
I used to own a 87 integra ls. It was in the family for 15 years. ince 1990.
I just sold it last month for $600 cahsh. and I keep in touch with the new owner.
Anyway, All the first gen itnegras rev over and over to warm them selves up.
However, I would think that yours is a problem.
The ecu flashing does not mean o2 sensor.
Count the flashes between pauses.
Check out http://www.G1teg.org
It's the master site for our, errr... I mean your Integra.
They will help you out with everything and anything.
Goodluck on the oldschool teg. I loved mine and I now wish I didnt sell it for my current DA9
Here is some First gen teg love,
GoodLuck with the 88 teg.
Old Oct 23, 2005 | 08:53 PM
v-tecgoswahn's Avatar
Default Re: 88 integra revving (90DA9IntegraRS)
i jus had the same problem it was a vaccuum leak jus check all vaccumm hoses and make sure everthing goes somewhere and if u cant figure it out jus plug up the hoses...what i was told
eastbay92cx
Dec 9, 2010 06:53 PM
ABCVTEC
May 22, 2007 12:37 AM
ximportman
May 2, 2007 05:31 PM
over-rev
Apr 19, 2006 12:43 PM
