What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other?
Old Oct 23, 2005 | 02:28 PM
tgh22a's Avatar
Default What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other?
I have searched around and have not found a sure answer to my question. I have a h22 that I want to put into a eg, but I have a skunk 2 intake manifold and want to make sure about the clearance to the fire wall. I know hasport and HCP are both good mounts. Will an h22 with a skunk 2 intake manifold clear the fire wall with either mounts?
If for some reason I didn’t find the post could you point me to the right direction.
Old Oct 23, 2005 | 04:08 PM
NXLude's Avatar
you may need to do a little adjusting
Old Oct 23, 2005 | 10:29 PM
Lost_Raider's Avatar
Default Re: What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other? (tgh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh22a &raquo;</TD></TR><TR><TD CLASS="quote">I have searched around and have not found a sure answer to my question. I have a h22 that I want to put into a eg, but I have a skunk 2 intake manifold and want to make sure about the clearance to the fire wall. I know hasport and HCP are both good mounts. Will an h22 with a skunk 2 intake manifold clear the fire wall with either mounts?
I know for a fact that the skunk2 IM will clear the firewall in an EG with HCP mounts by 2-3 inches. Clearance from the prop valve is slim though, less than an inch. Here is a link to the pics of the clearance with HCP mounts https://honda-tech.com/zerothread?id=924551
I dont know if the IM fits with Hasport mounts though.
Old Oct 27, 2005 | 11:03 AM
tgh22a's Avatar
Default Re: What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other? (Lost_Raider)
Thanks for the link Lost Raider, I called hasport and they said that you would have to bang in the firre wall with there mounts.
Modified by tgh22a at 10:35 AM 10/28/2005
Old Oct 29, 2005 | 09:26 AM
RAT FINK's Avatar
I just installed this intake yesterday and I didnt have to beat on the firewall,I did however move the brake distribution block about two inches lower.I have Hasport mounts in my eg with a H22
Rob
95egcoupe1
Feb 16, 2009 04:59 PM
tgh22a
Oct 23, 2005 03:45 PM
H22 EH!
Mar 23, 2005 10:03 PM
Terrible One
Jan 1, 2005 03:45 PM
