Switching oil brands
Old Oct 23, 2005 | 02:19 PM
Blazin Civic's Avatar
Default Switching oil brands
I have a 95 integra GSR I recently picked up and it is about time for an oil change. The guy before me always used royal purple synthetic oil in it and it always worked good but I have nowhere around me to get it. Is there any problem with switching to mobil 1 synthetic since they are both synthetic oils? The mobil 1 is just much more avaliable for me. Also I always had a D series setup...how much oil does a GSR take?
Old Oct 23, 2005 | 02:27 PM
Sack Master's Avatar
Default Re: Switching oil brands (Blazin Civic)
Just use what you like. There won't be a problem.
Old Oct 23, 2005 | 02:36 PM
low430's Avatar
Default Re: Switching oil brands (Sack Master)
mobil 1 is crap stick with castrol synthetic
Old Oct 23, 2005 | 02:50 PM
mlsmith95gsr's Avatar
Default Re: Switching oil brands (low430)
Any full synthetic oil should be fine.
GS-R's take 4.2 quarts but just check the dipstick
Old Oct 23, 2005 | 02:56 PM
I use redline in my tranny and my engine. Haven't had any problems. Most of the people I work with use royal purple and all seem to love it. I have some friends that use castrol, mobile, valvoline etc etc. As long as you take care of your car and have proper maintainence it should last no matter what. I think most people will agree that pennzoil is not the motor oil of choice though.
A friend at work used to build nascar engines. They switched from a regular motor oil to redline and got 17hp on the dyno(which is amazing). After that they tired an additive called tribotech and picked up another 12hp.
Old Oct 23, 2005 | 03:01 PM
Thats pretty interesting. How would you pick up HP from changing oil brands? 12hp is a lot of hp to pick up from changing oil.
Old Oct 23, 2005 | 05:18 PM
low430's Avatar
its nascar tests, you wont pickup 12 HP, you may pickup 0-3 hp due to the reduced in engine friction.
gooblinn258
May 12, 2014 10:54 AM
bowtieboy911
Jul 13, 2011 06:43 AM
nudo wo0do
Nov 9, 2004 10:02 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
Mike D
Jun 23, 2001 07:26 PM
